Re: 2006 300C SRT8 no start...brake switch?
[Re: moparx]
#3155332
06/29/23 06:04 PM
06/29/23 06:04 PM
Posts: 1,970 ID/MT
Cheeto
ID/MT
,,, if i were to replace one flex line [on any vehicle] i would replace them all, ,,, Even on a car whose sole purpose is to give up its engine for another project? If indeed it is the brake line causing it not to start I will likely just clamp it off to allow the system to build pressure. Again, I just want to hear this engine run before investing time/money/effort into it.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: Cheeto]
#3155351
06/29/23 06:58 PM
06/29/23 06:58 PM
Posts: 10,157 A Red State
SNK-EYZ
A Red State
I don't think that brake line pressure is the problem.
It's a wiring problem, but without actually working on the car themselves it's tough for people to tell you where the problem iles.
With it being wrecked there are so many places that there could be wiring damage.
It's just like any other old Mopar, it there is power at the starter (large hot lead) you should be able to feed power to the starter solenoid connection on the starter to make it crank over. Whether it would actually start with the key in the on position is a whole other story.
[Re: SNK-EYZ]
#3155415
06/29/23 09:29 PM
06/29/23 09:29 PM
Posts: 1,970 ID/MT
Cheeto
ID/MT
I don't think that brake line pressure is the problem.I was basing that off of previous advice but he hasn't followed up. without actually working on the car themselves it's tough for people to tell you where the problem iles.Completely agree. That's why I'm open to all suggestions. With it being wrecked there are so many places that there could be wiring damage.Again, I agree but everything else seems to work...well the broken headlights don't. When I get more time to truly get after it I'll check voltage at the starter and try jumping the solenoid. The shift indicator in the dash moves according to shifter position. Is there more than one sensor involved there?
[Re: Cheeto]
#3155420
06/29/23 09:48 PM
06/29/23 09:48 PM
Posts: 21,532 N.E. OHIO, USA
A12
N.E. OHIO, USA
The shift indicator in the dash moves according to shifter position. Is there more than one sensor involved there? Have you tried to start it in neutral ? Or just for grins in drive or all of the positions? Here is the neutral switch:
[Re: A12]
#3155446
06/29/23 11:33 PM
06/29/23 11:33 PM
Posts: 1,970 ID/MT
Cheeto
ID/MT
90% certain I tried it in neutral. I'll add "try all gears" to the list for when I get back to it. Thank you. Is that switch mounted on the trans or the shifter?
[Re: moparx]
#3155744
06/30/23 10:02 PM
06/30/23 10:02 PM
Posts: 1,970 ID/MT
Cheeto
ID/MT
sorry Cheeto........... i forgot you are just trying to get this engine to run, then transplant. them dang spiders............... No worries, I had to go back and make sure I even said that way back in the beginning. Excellent advice in a different scenario though.
