It's not supposed to look like that...
#3144646
05/15/23 06:41 AM
05/15/23 06:41 AM
Posts: 10,050 MN
JERICOGTX
MN
Wrecked on the 4th pass... A new Mark Williams Chromoly shaft has been ordered. Guess I won't be racing over Memorial Day Weekend.
69 GTX
68 Road Runner
Re: It's not supposed to look like that...
[Re: racerx]
#3144653
05/15/23 07:38 AM
05/15/23 07:38 AM
Posts: 10,050 MN
JERICOGTX
MN
.....Was that a stock shaft? No. Brand new aluminum shaft.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3144657
05/15/23 08:07 AM
05/15/23 08:07 AM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
.....Was that a stock shaft? No. Brand new aluminum shaft. Who built it? Hopefully MW will get your new one out quickly.
[Re: justinp61]
#3144659
05/15/23 08:21 AM
05/15/23 08:21 AM
Posts: 10,050 MN
JERICOGTX
MN
.....Was that a stock shaft? No. Brand new aluminum shaft. Who built it? Hopefully MW will get your new one out quickly. PEM. Mark Williams is 2 weeks out. My yoke is in route to them.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3144666
05/15/23 08:40 AM
05/15/23 08:40 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Good gracious! When did it happen? I bet it tried to shake the car apart! I've broken tailshaft housings from a twisted shaft that wasn't visible just looking at it.
[Re: bigdad]
#3144670
05/15/23 08:55 AM
05/15/23 08:55 AM
Posts: 2,530 PA
moparacer
PA
It's a wander that didn't try to eject itself from the car.... Is it the camera angle, or do I see lots of down pinion angle being used here?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: an8sec70cuda]
#3144672
05/15/23 09:04 AM
05/15/23 09:04 AM
Posts: 10,050 MN
JERICOGTX
MN
Good gracious! When did it happen? I bet it tried to shake the car apart! I've broken tailshaft housings from a twisted shaft that wasn't visible just looking at it. Happened on my 4th pass, on this combo. Didn't feel a thing until I pulled 3rd gear. Yes it shook the car hard. Scratched up the tunnel in the car. I drove it back to the trailer, and didn't feel anything then. Noticed it when I was looking things over.
69 GTX
68 Road Runner
[Re: moparacer]
#3144673
05/15/23 09:04 AM
05/15/23 09:04 AM
Posts: 10,050 MN
JERICOGTX
MN
It's a wander that didn't try to eject itself from the car.... Is it the camera angle, or do I see lots of down pinion angle being used here? Camera angle. Car is only jacked up in the rear.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3144678
05/15/23 09:37 AM
05/15/23 09:37 AM
Posts: 2,530 PA
moparacer
PA
It's a wander that didn't try to eject itself from the car.... Is it the camera angle, or do I see lots of down pinion angle being used here? Camera angle. Car is only jacked up in the rear. The bent part looks like it is lined up with the pinion and the driveshaft is running uphill to the trans is why I was asking. Almost looks like the driveshaft wasn't happy with whatever was going on there. I never liked aluminum anything on the driveshaft.....This just reinforces my opinion.
[Re: JERICOGTX]
#3144684
05/15/23 10:10 AM
05/15/23 10:10 AM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
ugh....The joys of more power. It could have been worse as I'm sure you are aware. MW is the stuff for sure, how long is that shaft? Wonder what material they use?
[Re: GY3]
#3144714
05/15/23 11:17 AM
05/15/23 11:17 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Just pop the clutch in reverse, should fix er up! HA Dang dude that really sucks, glad its nothing more than scratches in the tunnel for damage.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3144718
05/15/23 11:25 AM
05/15/23 11:25 AM
an8sec70cuda
Just pop the clutch in reverse, should fix er up! HA Dang dude that really sucks, glad its nothing more than scratches in the tunnel for damage. He probably has the car in a million pieces preparing for a tunnel repaint now!
