Page 2 of 6 1 2 3 4 5 6
Re: 700 hp default combo? [Re: rickstershemi] #31458
10/10/06 05:27 PM
10/10/06 05:27 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
ummm...not to pick a fight...but running 9.90's at 133 at 3400 pounds is far from 700 ponies...our smallblock runs those numbers or a hair quicker at pretty much the same weight...no where near 700 ponies
Sorry I have never dynoed the motor and the last time I weighed it it was 3490 but that number came from an e.t. to horsepower calculator sorry if you don't believe the power but this is a footbrake car with 4.30's. But it is pretty close. This wasn't a best e.t. either it was just my first time to the 1/4 mile with this motor.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 700 hp default combo? [Re: rickstershemi] #31459
10/10/06 05:27 PM
10/10/06 05:27 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have found a few new victors on fleabay for $1,399.00 a set with springs....?????
The don't come w/ springs from Edelbrock. And whether you get the ones that come w/ valves or not, they still need to have the guides clearanced and an actual valve job done, not the 45-deg. "slash cut" that Edelbrock puts on the inserts simply to give the valves something to butt up against during shipping.
Re: 700 hp default combo? [Re: AndyF] #31460
10/10/06 05:30 PM
10/10/06 05:30 PM
BradH Offline
BradH  Offline
... if you combine pump gas + real world driving + full exhaust it starts to get tough. The cam choice becomes very critical.
No doubt...
Re: 700 hp default combo? [Re: Jacob Pitt] #31461
10/10/06 05:31 PM
10/10/06 05:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
i wasnt trying to pick on ya ...3490 is heavier than 3400...lol...footbraking it wont make it any slower though...the duster will run identical laps off foot or brake...assuming hook.....i have just been using ryans moroso calculator for power"guesses"134 mph at 3350 pounds is 618 ponies...we ran 134.71 last weekend so i am guessing 630ish.....
edit..moparts calculator
3350..134.71...639
3490..133.50...648....ya got me
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 700 hp default combo? [Re: B3422W5] #31462
10/10/06 05:43 PM
10/10/06 05:43 PM
BradH Offline
BradH  Offline
3350..134.71...639
I'm also curious what the altitude #s are for the tracks where ChallyL427 races. From what I recall, a lot of those Texas tracks aren't at sea-level like HRP is, and some of them are pretty darn "up there" compared to the coastal region.
Re: 700 hp default combo? [Re: charger] #31463
10/10/06 05:49 PM
10/10/06 05:49 PM
AndyF Offline OP
AndyF  Offline OP
Charger - that sounds like a pretty good combo. The 440-1 heads do add some cost though as does the roller. I haven't done enough different motors with Indy heads to really have a good feel for the difference between EZ, SR and -1 heads. My take on it is that if the EZ heads will get you the number you're shooting for then that is the way to go. But of course, the EZ's are a fairly new option so there are lots of guys running the SR and -1 combo's just because they bought those parts before the EZ heads were available.
Re: 700 hp default combo? [Re: BradH] #31464
10/10/06 05:59 PM
10/10/06 05:59 PM
Lehigh Acres, Florida
rickstershemi Offline
Edelbrock #77929 Victor Big Block Chrysler Bare heads with Valves. This Listings is for Bare Heads with Valves. These heads are supplied with valves, HAVE finished Guides, and Valve JOB done from EDELBROCK. These heads require offset rocker arms for the intake ports; use Mopar Performance .485" offset intake rockers. The exhaust side will accept standard-spec rockers.
Intake and Exhaust Valves Included. The best standard port location head available for competition big-block Chryslers
Intake ports are raised .650", exhaust ports are raised .250" for improved flow
Will fit existing Victor manifolds for both high and low deck engines
Standard 15-degree valve angles
280cc intake ports and 100cc exhaust ports
Raised valve cover rails and dual quench 75cc combustion chambers
Sold without springs or retainers- use recommended springs to match your cam
Can be machined to match Max Wedge ports.
Sorry it was Valves, not Valve Springs...
My take was this 700hp build was supposed to be an inexpensive off the shelf type of build, without extensive machining, porting, etc...???
Rickster
Re: 700 hp default combo? [Re: rickstershemi] #31465
10/10/06 06:38 PM
10/10/06 06:38 PM
AndyF Offline OP
AndyF  Offline OP
I haven't seen any Victor heads on the dyno yet but I really doubt that they are going to go 700 hp OOTB with an OOTB Victor manifold on a 505 shortblock.
By the time you port them to max wedge size and buy the special offset rocker arms you'll most likely have as much in them as a set of ported EZ heads.
As soon as someone has dyno info and prices then we'll know if the Victor's are a good deal or not.
Re: 700 hp default combo? [Re: AndyF] #31466
10/10/06 08:07 PM
10/10/06 08:07 PM
Regina, SK, Canada
charger Offline
charger  Offline
Regina, SK, Canada
I think I could have netted the same result using any of these heads...I used the 440-1's simply because I already had them, and I also wanted to leave some HP on the table for a later upgrade, plus I also thought the bigger port volume might be better for that 175 Shot of laughing gas I plan on tossing at it
Re: 700 hp default combo? [Re: rickstershemi] #31467
10/10/06 09:44 PM
10/10/06 09:44 PM
Massachusetts, USA
maxeffort Offline
maxeffort  Offline
Massachusetts, USA
I do quite a few edelbrocks and every set needs the guides clearanced, good valve job, resurfacing and new springs to be acceptable.
Still, they are a good value and a decent casting. better to buy them bare and set them up correctly.
official member of the Sleepy Labeef band alumni club.
Re: 700 hp default combo? [Re: maxeffort] #31468
10/10/06 09:59 PM
10/10/06 09:59 PM
Whats a bare set worth.??? I was just making a contribution to the thread, I'll be using B1's on my 511 build...!!!!
Rickster
Re: 700 hp default combo? [Re: rickstershemi] #31469
10/11/06 01:23 AM
10/11/06 01:23 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Great thread Andy..
While I agree that the EZ's are more than capable of reaching the #, and definitely more economical...The "Default Combo" would probably include Indy 440-1's simply due to the huge numbers of these heads already in racers hands! I'd venture to guess that a larger group of racers looking to move into the 700HP range, will be putting strokers under thier existing heads, rather than putting larger heads on existing shortblocks.
In my case, I absolutely love my 440 with Edelbrock Performers, M-1, and 304/640 ultradyne solid. With a best of 9.96-133 on the motor in a 2880 lb Challenger, and around 129-130 in SST, it has served me well for 5 seasons.
So I want to step up without robbing anything from that engine, allowing it to serve as a back-up or for another project.
Here's what I have so far to that end:
'70 RB Block, 4.350 bore, tall fill, BRC aluminum Caps & ARP Studs.
OOTB 440-1 heads: they will be prepped, and cleaned up by my machinist.
1150 Dominator, Milodon Dragster pan w/ single line system, 2 1/8 headers
My plan was to use the 4.25/7.1(2.2 journal)/Ross flattop kit from 440 Source.
I don't have an Intake yet, I was considering a 440-2 since I already have an adapter which has 2 stages of N20 plumbed in, hood clearance may be an issue however, so the 440-3 with a fogger may be the answer?? The 3X is out of the question...it'll never fit.
After watching my brother struggle to keep Indy rockers alive on his 504..(he finally made a whole season this year..by dumping his roller cam, and going with, you guessed it A .620 MP Solid!!) I'm definitely getting T&D's..So do I get 1.6, 1.65, 1.7??
Next question is Cam...I have a 280/282 @.50 .660 lift roller (w 1.5) 108 LSA available on the shelf...I'd really love to get it done with a solid though.
The goal is this: I'd like to go 8.99-148 once on motor, In my 2880 lb Challenger with a 1.76 Glide, and 9 inch converter, 4.30 gear. Consistant 9.10-9.30's would be fine, 142 mph in 10.90, 144 mph in 9.90 trim.
Is that doable with a default 700 hp combo?? do I need more? Can I hit it with any N20 at all without grenading it??
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 700 hp default combo? [Re: AndyF] #31470
10/11/06 02:07 AM
10/11/06 02:07 AM
gregsdart Offline
gregsdart  Offline
Andy, i don't know about 700 hp, but i have what i believe would be a very reliable 800 hp combo in my head, based on parts i have used.
499 low deck shortblock , BME aluminum rods with a small dome piston for at least 13/1 compression.
Indy 440-1 heads, cnc ported, dominater single four
Isky RR735 roller with jesel rockers, comp 947 springs.
Put this in a 3000 lb package and go 9.10s all day long at 7200 rpm, faster if you don't live in minnesota!.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: 700 hp default combo? [Re: rickstershemi] #31471
10/11/06 07:55 AM
10/11/06 07:55 AM
Massachusetts, USA
maxeffort Offline
maxeffort  Offline
Massachusetts, USA
Rickster
a bare set of regular edelbrocks is around $1400.
Please note that I never have used the Big Block mopar ones. I do a few of the pontiac edelbrock heads though.
Re: 700 hp default combo? [Re: maxeffort] #31472
10/11/06 10:33 AM
10/11/06 10:33 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
http://www.wallaceracing.com/Calculators.htm
This is the calculator I use it has been very close on e.t. predictions and such.
14x Track Champ
Re: 700 hp default combo? [Re: MoparBilly] #31473
10/11/06 12:18 PM
10/11/06 12:18 PM
AndyF Offline OP
AndyF  Offline OP
Hi Billy, good point on the 440-1 head. No doubt that if people have them then it would be better to use it than switch to something smaller. I guess my point with the thread was to lay out a moderate cost solution for the guy who was starting with nothing more than a bare block.
The 440-1 heads add some cost with the special rocker arms but they also add more potential for futher upgrades down the road.
700 hp should put 2880 lbs thru the lights at about 145 mph so that seems about right. I really don't know if OOTB 440-1 heads are as good as or better than the fully ported EZ heads. I've never done a back to back with those two.
Re: 700 hp default combo? [Re: AndyF] #31474
10/11/06 04:08 PM
10/11/06 04:08 PM
What does one consider "moderate cost" for this build in total dollars spent....????
Rickster
Re: 700 hp default combo? [Re: AndyF] #31475
10/11/06 04:24 PM
10/11/06 04:24 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Our 451 made 659hp and 633 tq with sr heads with nothing but a little cleanup work under the valves using a m1 untouched intake. I'd think a 505 should go 700 easy.
Re: 700 hp default combo? [Re: rickstershemi] #31476
10/11/06 04:27 PM
10/11/06 04:27 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Rickster
I saw a post the other day where Andy said he could sell a 700 hp engine for a certain $ figure - if it's the same one.
Everybody makes fun of a hillbilly until they need something fixed
Re: 700 hp default combo? [Re: B3422W5] #31477
10/11/06 05:26 PM
10/11/06 05:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
His rwhp should be about 640hp. My guess is about 765hp flywheel.
