70 E body build sheet codes? #3141544
04/30/23 02:42 PM
04/30/23 02:42 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
Needing some help with decoding a 70 E build sheet. I think some of the codes are shifted a bit.
1) What are the correct G codes for this car? Is it just G11 and G36????
2) What are the correct M, N, P, R & S codes for this car?
3) Also curious about the codes in section 11. I do not have any info on how to decode this section.
Also, This car is said to be an N96 shaker car. The N96 code is missing on sheet. Any other way to confirm from build sheet info that it is a shaker car?
Thanks in advance for your help.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 E body build sheet codes? [Re: 70gtx440dana] #3141552
04/30/23 03:50 PM
04/30/23 03:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
many September/October (of 1969) '70 model year cars were built with 1969 broadcast sheets - the codes are in their correct place, but the '69 layout is different
G-codes = G11, G36, G41
M-codes = M21, M25, M26, M31, M71, M72, M83, M88
N-codes = N41, N42, N65, N51, N96
P-codes = NONE
R-codes = R11
S-codes = S15, S25, S31, S81
example below of an E-SERIES sheet '70 car that I "RECONSTRUCTED" to ease the decoding process grin
Re: 70 E body build sheet codes? [Re: 6bblgt] #3141590
04/30/23 07:00 PM
04/30/23 07:00 PM
Lansing, MI
Lansing, MI
6bblgt - Thanks for the detailed info. Are yu able to provide the other codes in sections A-L as well?
Re: 70 E body build sheet codes? [Re: 70gtx440dana] #3141893
05/02/23 12:37 AM
05/02/23 12:37 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A22 A32
B41 B51
C16 C55 C93
D32
E87
F25
G11 G36 G41
H11
J15 J25 J31 J45
Re: 70 E body build sheet codes? [Re: 6bblgt] #3141942
05/02/23 10:17 AM
05/02/23 10:17 AM
Lansing, MI
Lansing, MI
Thanks for the info....,much appreciated
