Re: Replacing a high mile 5.7 for a lower mile one
[Re: Dart 500]
#3142409
05/04/23 01:20 AM
05/04/23 01:20 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Can you not just put a complete OEM eagle 2009+ hemi in it? I'm not certain but I suspect that there are numerous differences in the wiring, the fuel injectors, the PCM and who knows what else.
[Re: Kern Dog]
#3142483
05/04/23 11:45 AM
05/04/23 11:45 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Dave won't he start throwing codes with the Eagle Heads? [/quote] Yeah, I would. The Eagle heads don't have an EGR valve. Mine does. [/quote] Takes about 2 minutes with a hand drill to add the passages, it is zero issue at all.
[Re: HotRodDave]
#3142598
05/04/23 09:49 PM
05/04/23 09:49 PM
Kern Dog
Granite Bay CA
If I knew of someone nearby that knew about this stuff, it sure would help. This isn't like the old days where just about every machine shop guy knew the specs of the common engines off the top of his head. I'm sure there are plenty of tricks to wake up these engines and make more power while still remaining reliable. I hate to come across like the crusty old dude that refuses to deviate from stock because thats how they built them when they were new so thats how I'm going to build this one.
That isn't the case. Emissions compliance is a big factor if you live where there is testing. Adding EGR is an interesting thought but I'd still have to consider the compression ratio difference. It was stated that there was a fuel economy increase with the higher compression. I understand that. I'm still pondering if it balances out ....overall fuel costs for each mile. I'm guessing that all of the gains in HP from 2008 to the 2009+ engines is from multiple points. VVT, improved efficiency in the port design, active intake manifolds, different exhaust manifolds, etc. The 2008 was rated at 345 HP. The 2009 was 395. Is 50 HP in a 5000 lb truck that noticeable? How much of that gain is from the heads? I'd suspect that the biggest gains were from the cam timing. If a 2006-2008 5.7 were fitted with these Eagle heads bumping compression about 2 points, I see that one would gain power from the compression increase as well as from the improved head design. In the past, it was thought that each point of compression can make a difference in HP of about 4%. 8% added to 345 is 372. Add in the increases from the head flow, are we now closing in on the Eagle 395 HP number? For a classic car, I don't mind running 91 octane premium all the time. I don't drive the car nearly as much as this truck.
[Re: Kern Dog]
#3142831
05/06/23 01:32 PM
05/06/23 01:32 PM
HotRodDave
Kalispell Mt.
I get more than 8% better economy, more like 20% but it comes from more than just increased engine efficency from compression increase. The ratio increase alone is just over 2.5 points more so about 10% less fuel just on that but there is also more airflow, double quench pads. Also the increased TQ from all that means a lot less downshifting around here so if you live and drive on long flat roads you may not see much improvement from that if it don't down shift a lot already. Without tuning the extra airflow and exhaust flow means the ratio is gonna be leaned out significantly when it is not adjusting for the o2 sensor readings. Also since it requires less throttle opening and higher vacuum in the intake the computer advances the timing more so all in all there is a lot more advantage to the swap that strictly having more compression.
[Re: Kern Dog]
#3143528
05/09/23 10:06 PM
05/09/23 10:06 PM
HotRodDave
Kalispell Mt.
A flat piston has less surface area for it to absorb heat. Smaller chamber more compression and the dual quench pads give the fuel/air mix and extra mix right bee four ignition. It also flows more air because of improved ports and bigger valves.
