Re: Straightening a bent axle housing [Re: moparx] #3143665
05/10/23 02:09 PM
05/10/23 02:09 PM
moparx Offline
moparx  Offline
how far off were you Joel ?
beer
Re: Straightening a bent axle housing [Re: moparx] #3143671
05/10/23 02:23 PM
05/10/23 02:23 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
beer
Before and after:
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Straightening a bent axle housing [Re: Hemi_Joel] #3145030
05/16/23 07:48 PM
05/16/23 07:48 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I made a heavy duty work stand to straighten rear ends and shorten them. To straighten them I use a 1.5" tri bar run thru the housing with bushings where the bearings are. Working on one end I slide the bushing out and use a hyd jack to move the housing where the bushing will side in. This takes some time to get just rite. When I shorten a rear end I make sure the ends are square as I'm welding them. After all the welding is done I straighten the housing. I have rebuilt and straightened several rear ends and only one housing did not need straightening.
Re: Straightening a bent axle housing [Re: convx4] #3150684
06/12/23 12:38 AM
06/12/23 12:38 AM
WA
Air Grabbler Offline OP
WA
Convx4, that is a really nice jig! I’m embarrassed to show the makeshift jig I cobbled together.
But it worked.
I used a 20 ton bottle jack and a torch to straighten the D60 tubes. Now I need to cut one housing end off and weld a Moser end on. The bearing bore diameter of the Moser ends are too tight to slide a bearing race so I’ll have to address that before welding them on.
Thanks for all the input and recommendations.
