Re: Car stalls on hard braking
[Re: captaindodge]
#31424
10/05/06 07:53 PM
10/05/06 07:53 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Do you remember the fix having to do with adding a second fuel supply line on the driver side of the AVS
No second fuel supply.If I remember it had something to do with the booster nozzle modification.May take a while but I'll find it..
[Re: 62maxwgn]
#31428
04/26/07 10:47 PM
04/26/07 10:47 PM
Posts: 279 pgh pa
captaindodge
pgh pa
![](/ubbthreads/images/graemlins/bump.gif) Quote: -------------------------------------------------------------------------------- Do you remember the fix having to do with adding a second fuel supply line on the driver side of the AVS -------------------------------------------------------------------------------- No second fuel supply.If I remember it had something to do with the booster nozzle modification.May take a while but I'll find it..
[Re: 62maxwgn]
#31431
11/22/08 06:13 PM
11/22/08 06:13 PM
Posts: 279 pgh pa
captaindodge
pgh pa
Quote: I have same problem with my AVS 4bbl on 440 Charger, but it will also stall on hard left turns but hard right turns are no problem. (this is with foot off gas pedal). Setting float level low seems to help but no solve the problem. There is a fix for that in the old Tech Bullitens.If I can find it I'll post it. 62maxwgn did you ever find that Tech Bulliten? ![](/ubbthreads/images/graemlins/scope.gif)
