Glass-beading Holley carb parts? #3140229
04/23/23 08:25 PM
04/23/23 08:25 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
I picked up a Holley 6299-1 (390 CFM 4-barrel) at a flea market for really cheap so I couldn't pass it up. Definitely in need of a clean and rebuild when I get a chance to tinker with it. No, I'm not going to put it on my big-cammed 451 whistling
Can I glass-bead everything I want to clean, or only the outside of the body, or not even that? work
I am concerned that it would have the same effect as glass-beading pistons (i.e. abrasive gets stuck in the surface of the metal and wears the crap out of the bore as well as ending up in the oil)... pot-metal isn't very hard either.
Re: Glass-beading Holley carb parts? [Re: DrCharles] #3140237
04/23/23 08:46 PM
04/23/23 08:46 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Personally I would never glass bead a carburetor or throttle body or a few other things that might get glass beads into small passages. I would use a ultrasonic cleaner or a vapor cleaner or even soaking it in a carburetor (liquid) cleaner. You'll never IMO get all of the glass beads out of it. Just my opinion.
Re: Glass-beading Holley carb parts? [Re: A12] #3140245
04/23/23 09:07 PM
04/23/23 09:07 PM
West Plains, MO
West Plains, MO
Thanks! I hadn't thought of plugging passages with beads, they're pretty tiny too wink I don't have those cleaners although some day I want to get an ultrasonic cleaner big enough to put a carb into up So I guess it's disassemble and soak time!
The "Berryman Chem-Tool Carb Dip" (comes in a gallon paint can with a basket) used to be some volatile whitish milky stuff that really worked. The last time I bought one, though, they'd changed the formula and it's brown and really different smelling. Probably more environmentally penguin-friendly but not as effective, just like the de-chlorinated carb cleaner sprays.... rolleyes
Anyhow the carb is complete, doesn't have any obvious damage, and was $5 so I don't have that much to lose wink
Re: Glass-beading Holley carb parts? [Re: DrCharles] #3140260
04/23/23 10:30 PM
04/23/23 10:30 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
You can get a nice ultrasonic cleaner large enough to put a 4bbl carb in for about $150 (or less try searching Amazon) that will do a nice job. Then see if someone local has a vapor cleaner and how much to do your carb(s) or save your pennies or hint for a birthday gift or Christmas present grin
Re: Glass-beading Holley carb parts? [Re: A12] #3140287
04/24/23 07:33 AM
04/24/23 07:33 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I blast them with baking soda.
Re: Glass-beading Holley carb parts? [Re: B1MAXX] #3140291
04/24/23 07:43 AM
04/24/23 07:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
It's been brown for over 25 years ... that's when I bought the can that's on my shelf ! It's awesome stuff though and doesn't appear to have an expiry date !!
Re: Glass-beading Holley carb parts? [Re: Stanton] #3140321
04/24/23 10:15 AM
04/24/23 10:15 AM
West Plains, MO
West Plains, MO
Originally Posted by Stanton
Quote
That tracks, I think I got the white stuff in the early 90's laugh
