Re: New Morrison K frame assy
[Re: cudacam]
#3173302
09/06/23 10:40 AM
09/06/23 10:40 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Any shots of how the lower control arms attach to the frame and the structure in that area?
Carl Kessel
[Re: cudacam]
#3173306
09/06/23 11:06 AM
09/06/23 11:06 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Who owns that, ie what are we looking at, a press release, or a buyer's new IFS? That is 4.75" BC?
[Re: TC@HP2]
#3174266
09/10/23 07:29 PM
09/10/23 07:29 PM
jcc
Bitopia
I agree, except with the non-concern of the SB cut out. I can't see it being that difficult in just downsizing the size of the cut out and making it the holder of the SB with a poly? bearing and closing off the bottom of that member with a structural cap. That would also allow for an upgraded splined SB, especially nice if a straight one would miss the engine damper which is in that area I suspect. The unibody for track use can always be more robust IMO. I thought there were new anti-dive considerations with this set-up to explain the control arm angles vs say a RMS set up. That is only a guess though.
[Re: TC@HP2]
#3175040
09/13/23 08:28 PM
09/13/23 08:28 PM
jcc
Bitopia
My guess is there must have been some travel 3d space conflict between the SB and the front steering links to explain the notch solution chosen and/or wanted to maybe use an existing Morrison off the shelf SB from another application. Your idea would have been the most straight forward if doable. I asked if they would share the suspension measurements for strictly my own use if I purchased and took delivery of one AND signed a NDA, and that was a no go.
[Re: jcc]
#3197706
12/15/23 11:45 AM
12/15/23 11:45 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Sweet. Make one for an A-Body. A lighter platform.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: brads70]
#3210571
02/04/24 05:27 PM
02/04/24 05:27 PM
jcc
Bitopia
I don't do much autocross, but seeing it with my own eyes design wise, it's a bit overtkill and pricey at first glance for autocross IMO. It's one beefy piece of hardware. Its a brake when you see God item.
