Re: New Morrison K frame assy
[Re: cudacam]
#3173302
09/06/23 10:40 AM
09/06/23 10:40 AM
Posts: 679 Los Osos, Ca
CKessel
Los Osos, Ca
Any shots of how the lower control arms attach to the frame and the structure in that area?
Carl Kessel
[Re: cudacam]
#3173306
09/06/23 11:06 AM
09/06/23 11:06 AM
Posts: 23,230 Here
jcc
Here
Who owns that, ie what are we looking at, a press release, or a buyer's new IFS? That is 4.75" BC?
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: TC@HP2]
#3174266
09/10/23 07:29 PM
09/10/23 07:29 PM
Posts: 23,230 Here
jcc
Here
I agree, except with the non-concern of the SB cut out. I can't see it being that difficult in just downsizing the size of the cut out and making it the holder of the SB with a poly? bearing and closing off the bottom of that member with a structural cap. That would also allow for an upgraded splined SB, especially nice if a straight one would miss the engine damper which is in that area I suspect. The unibody for track use can always be more robust IMO. I thought there were new anti-dive considerations with this set-up to explain the control arm angles vs say a RMS set up. That is only a guess though.
[Re: TC@HP2]
#3175040
09/13/23 08:28 PM
09/13/23 08:28 PM
Posts: 23,230 Here
jcc
Here
My guess is there must have been some travel 3d space conflict between the SB and the front steering links to explain the notch solution chosen and/or wanted to maybe use an existing Morrison off the shelf SB from another application. Your idea would have been the most straight forward if doable. I asked if they would share the suspension measurements for strictly my own use if I purchased and took delivery of one AND signed a NDA, and that was a no go.
[Re: jcc]
#3197706
12/15/23 11:45 AM
12/15/23 11:45 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Sweet. Make one for an A-Body. A lighter platform.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: brads70]
#3210571
02/04/24 05:27 PM
02/04/24 05:27 PM
Posts: 23,230 Here
jcc
Here
I don't do much autocross, but seeing it with my own eyes design wise, it's a bit overtkill and pricey at first glance for autocross IMO. It's one beefy piece of hardware. Its a brake when you see God item.
[Re: TC@HP2]
#3251248
08/13/24 05:31 PM
08/13/24 05:31 PM
Posts: 573 USA
Hooligan
USA
I have never rode in or driven a Mopar with one of those expensive coil-over conversion kits. I've watched videos of guys disliking them, but if smoking hot chicks dig it, that's all that matters!
