Page 3 of 3 1 2 3
Re: Availability and Prices of ATF Recently [Re: CMcAllister] #3130239
03/17/23 10:10 PM
03/17/23 10:10 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Walmart Supertech is made by the same company that makes Mag 1. Very possibly exactly the same fluid.
Re: Availability and Prices of ATF Recently [Re: GomangoCuda] #3130276
03/18/23 08:58 AM
03/18/23 08:58 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If it says type F on it I run it and I race more than most. Mags, Walmart, whatever. I build my transmissions so I see what is going on. Ohhh and there isn’t a much harder test than a 6000 Stall converter on the floorboard with a transbrake.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Availability and Prices of ATF Recently [Re: pittsburghracer] #3130296
03/18/23 10:46 AM
03/18/23 10:46 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Im with pittsburgh racer. Any type f, I have ran a bunch of different brands. Cheapest I found is at rural king providence automotive brand. You can order online and its $5.50 a quart. Last year I bought a few cases of it for $4 a quart. I am also trans brake and 6500 stall converter.
Re: Availability and Prices of ATF Recently [Re: GomangoCuda] #3130351
03/18/23 03:02 PM
03/18/23 03:02 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Very possible.
However, Mag 1 oil is indeed the cheap stuff sold to shops that do cheap oil changes and I know a number of guys using Walmart Type F in good transmissions. Not Top Sportsman level stuff. More like Stockers and Super Stockers.
Personally, I would not be likely to use it. Mostly because I try to avoid Walmart.
Page 3 of 3 1 2 3
