just a side note on valve recession using unleaded gas with cylinder heads not having hardened seats.
i have seen quite a few over the years after tear down that looked remarkably good. these came from engines that were driven reasonably normal, and not beat on every time out.
i have also seen heads from engines that were beat on frequently, and the seat areas weren't as bad as i thought they should be.
with that said, several times over the years it has been suggested mopar used a better grade of cast iron than ford or gm, and that explains why the seats weren't pounded out like i expected they should be.
how true any of this is, who knows ?
i have seen beat seats and junk guides as well. just my life experiences playing with this brand.
your mileage will vary.
