Re: Drag race MSD distributor locked or not?
[Re: CMcAllister]
#3129404
03/14/23 05:17 PM
03/14/23 05:17 PM
Posts: 4,457 Washington
madscientist
Washington
Unless there is an electronic “box” that’s providing some sort of “curve”, everyone running a crank trigger has the timing locked out. So? Does that mean it’s what the engine really wants? I doubt it, as most engines I know want a curve of some sort. Why? Drag race? I've never had a drag race engine run at anywhere below 5000, after the hit, unless it was on the stop for .90 racing for a few seconds. Most of the time, they are well above 3k before the hit. Unless it's a street driven, foot brake non-two stepped or Heavy Eliminator deal, I don't know anyone else who would spend any amount of time below 3K. Now I do know people who need to use timing retard for any number of reasons at different places on the race track. So I are saying an engine doesn’t need a timing curve as long as the RPM is 5000-9000k? I don’t see it that way.
[Re: madscientist]
#3129441
03/14/23 06:48 PM
03/14/23 06:48 PM
Posts: 12,331 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Unless there is an electronic “box” that’s providing some sort of “curve”, everyone running a crank trigger has the timing locked out. So? Does that mean it’s what the engine really wants? I doubt it, as most engines I know want a curve of some sort. Why? Drag race? I've never had a drag race engine run at anywhere below 5000, after the hit, unless it was on the stop for .90 racing for a few seconds. Most of the time, they are well above 3k before the hit. Unless it's a street driven, foot brake non-two stepped or Heavy Eliminator deal, I don't know anyone else who would spend any amount of time below 3K. Now I do know people who need to use timing retard for any number of reasons at different places on the race track. So I are saying an engine doesn’t need a timing curve as long as the RPM is 5000-9000k? I don’t see it that way. Why would it? Why not baseline it at max timing and control any desired retard from there electronically according to when and why it is desired? That's what most people are doing. Pulling power out of it is the only reason to pull timing on a race situation. Taking the ignition trigger out of the distributor and putting it on the crank is always better. If you can't do that, a locked distributor is the next best option. Although, you will still have timing chain slack, cam twist, gear clearance, oil pump load, etc., causing some degree of scatter to deal with.
[Re: CMcAllister]
#3129443
03/14/23 06:58 PM
03/14/23 06:58 PM
madscientist
Washington
Ok. I won’t lock one out. The OP is NA, and he didn’t say he’s running 9k. Lock out whatever you want. But the laws of Physics that govern combustion chamber dynamics doesn’t change.
[Re: dvw]
#3129707
03/15/23 05:24 PM
03/15/23 05:24 PM
Posts: 43,748 Bend,OR USA
Cab_Burge
Some ECU won't fire the coil until the starting of the third crankshaft revolution I've been told Any motor I have had that had 19 BTDC timing or more at idle or start up would kick back against the starter, even broke the nose off of one starter when it kick back against it
[Re: mopar dave]
#3129738
03/15/23 08:09 PM
03/15/23 08:09 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have heard of the circle track guys running a curve. They say the cars pull harder out of the corners, but i dont think we are talking circle track stuff here. Buddy of mine has an engine shop, does a lot of late model dirt stuff, as well as drag and resto. Good stuff. I'm going to have to call him tomorrow and see what he does now.
[Re: CMcAllister]
#3129744
03/15/23 08:42 PM
03/15/23 08:42 PM
madscientist
Washington
I have heard of the circle track guys running a curve. They say the cars pull harder out of the corners, but i dont think we are talking circle track stuff here. Buddy of mine has an engine shop, does a lot of late model dirt stuff, as well as drag and resto. Good stuff. I'm going to have to call him tomorrow and see what he does now. That would be awesome. I’d love to hear what he does.
[Re: mopar dave]
#3129782
03/15/23 11:54 PM
03/15/23 11:54 PM
madscientist
Washington
William Baldwin at Baldwin carbs is who i'm speaking of. He has a distributor machine for dialing the curve in. He’s the guy that called me out for locking out distributors on this very forum. I was so wrong (and he was so right) I went and bought a distributor machine so I can test this stuff and set up a proper curve.
[Re: madscientist]
#3130154
03/17/23 02:27 PM
03/17/23 02:27 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Talked to my engine guy this AM. Legit shop. Do a lot of engines.
Everything he does gets a crank trigger. If the rules don't allow it, distributor is locked. None of "that springs and weights stuff" for many years.
Drag race uses ignition, Grid, whatever for retard, if needed for tire management, nitrous, etc..
Dirt uses crank trigger locked with no gadgets. Some of them will also use a locked distributor with a pickup to run a separate system (box, coil) set up at 4 or 5 degrees retarded they can switch to for when the track slicks up. Or they will slip a restrictor under the carb to take some power out of it before they go out.
That's all I'm saying.
[Re: Moparrob68]
#3130171
03/17/23 03:26 PM
03/17/23 03:26 PM
Posts: 4,219 New York
polyspheric
New York
Locked is a safe position: fewer variables. However: consider coming off the trailer, pit driving, and return road. If you have a high stall converter, you're (probably) safe. With tall ratio MT cars, forgetting to slip the clutch that one time, followed by low RPM part-throttle acceleration, will rattle badly.
Boffin Emeritus
