2017 Jeep 3.2 engine, any problems?
#3125992
03/02/23 06:40 PM
03/02/23 06:40 PM
Posts: 2,564 God's Country Maryland
GODSCOUNTRY340
Looking to buy a 2017 Jeep Cherokee with the 3.2 V6. Anyone have any insight on this engine? Problems?
Re: 2017 Jeep 3.2 engine, any problems?
[Re: GODSCOUNTRY340]
#3126376
03/04/23 09:47 AM
03/04/23 09:47 AM
Posts: 13,227 aZLiViN
J_BODY
aZLiViN
We have three 2019 Trail Hawks in the family. 190k combined miles, NO issues. Mpg isn’t that great, but we have really enjoyed owning it. 19 and newer had WAAYYY better headlights
[Re: J_BODY]
#3126941
03/06/23 11:46 AM
03/06/23 11:46 AM
GODSCOUNTRY340
Thanks for the responses so far. After checking internet sites I noticed there is a class action lawsuit against Fiat/Chrysler for the 3.6 & 3.2 V6 engines for rocker arm/cam failure. It states the rollers on the rockers are failing causing the rocker arms to eat the cam lobes. If there's a class action suit that means there's more than one party involved in the legal action. I hate to say this but I'm starting to lean toward a Toyota Rav4, much better reviews.
#3126943
03/06/23 11:56 AM
03/06/23 11:56 AM
Posts: 862 Avondale AZ
Prodart440
Avondale AZ
I have a 2015 Grand Cherokee with the 3.6l. The only issue I have had with it was the rocker arms. I had one bad one, and you could hear the tick from a mile away. I changed all of them (that job sucked!!), and it has been problem free since. I suspect the dealership that was giving me free oil changes was using the wrong weight oil, as I caught them putting 10/30 in one time. Make sure the oil is changed religiously with the right weight.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
#3127028
03/06/23 05:30 PM
03/06/23 05:30 PM
Posts: 6,024 Morningside
AdventurerSport
waaaay out there in left field
Morningside
We have a 2016 Cherokee Limited 4x4 with the 3.2L V6 that we bought new in the Fall of 2016. My wife just turned over 100,000 miles last week. Only issue we ever had was one day it started missing, we took it to the dealership and one of the coils had failed. They replaced the coil and the oil filter canister (was leaking) under warranty. Other than oil changes, tires and brakes, that's all we've done to it since new.
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: moparjim79]
#3127192
03/07/23 10:15 AM
03/07/23 10:15 AM
GODSCOUNTRY340
Looking to replace my wife's 2008 Grand Cherokee closing in on 99,000 miles, 3.7 V6. Really like this Jeep, just the normal replacement parts; complete exhaust, two starters, 3 crank sensors, two O2 sensors and the normal tires and brake pad replacements. Since reading about the 3.2 & 3.6 engine problems (Google it) not sure about the newer Jeeps. We live in the mountains and really don't want the 2.0 4 cylinder engine, and she doesn't want the gas eating hemi. Told her she could use the '54 Power Wagon but it has a 440 in it, she just gave me "The Look".
[Re: volaredon]
#3127195
03/07/23 10:26 AM
03/07/23 10:26 AM
Posts: 1,337 Nor here, Nor there
Dart 500
Nor here, Nor there
I haven't heard of a 3.2 from Mopar since the intrepid's went away Its a smaller 3.6 pentastar only used in cherokee
[Re: volaredon]
#3127559
03/08/23 04:40 PM
03/08/23 04:40 PM
AdventurerSport
Morningside
I haven't heard of a 3.2 from Mopar since the intrepid's went away As stated, that's the smaller Pentastar V6 (same engine family as the 3.6L). The 3.2L Version (as far as I know) was only used in the Jeep Cherokee (14-23). It's the optional V6 in all years. My 2016 has the 3.2L V6 as mentioned above as well. Pretty trouble free for us other than the one coil failure (under warranty) and the leaky oil filter canister (also replaced under warranty). JS
[Re: moparx]
#3127810
03/09/23 01:46 PM
03/09/23 01:46 PM
AdventurerSport
Morningside
Yes, the oil filter canisters are mounted near the top of the engine (filter changed from top) and very handy to use (in my opinion). Some of the early Pentastar V6s (3.6L and 3.2L) had issues with these leaking (it was a new design in 2011 with the 3.6, and slightly updated for the 3.2 in 2014). Our 2016 was leaking (slightly) when the coil went bad and was found (under warranty). Not a huge leak, but "seeping" so it was replaced under warranty as well.
Google some photos and you can see the oil filter canister on top of the engine (and it does make it super easy to change the filter).
JS
[Re: AdventurerSport]
#3127879
03/09/23 05:36 PM
03/09/23 05:36 PM
Posts: 8,451 Highland, MI.
Sunroofcuda
Highland, MI.
JS My 2014 300 with the 3.6L suffered a cracked oil filter housing at about 31,000 miles. It was replaced under warranty. I first noticed it one evening in our garage - smelled like a burning belt. After a couple more times, I realized it was burning oil. They were notorious for doing this - the plastic assembly would crack & allow for oil to leak & start cooking on the top of the engine. So far, this has not happened on our 2016 300, but on cold starts, there is a sound like old solid lifter engines had from the valvetrain. I've had 2 different dealers look at this & both claim the rockers are good, even though the 3.6's are notorious for this problem. I'm almost out of drivetrain warranty, I'm thinking of selling it.
[Re: burdar]
#3128131
03/10/23 01:09 PM
03/10/23 01:09 PM
AdventurerSport
Morningside
I worry it's going to break every time I put a socket on it. When removing the cap, oil runs down into the valley if you don't plan ahead. I've started shoving a rag down in the space between the filter canister and the timing cover(?) to catch the spill. On mine, I drain the oil first, then remove the filter and install the new filter and seal. I haven't had any run downs doing it this way. JS
[Re: Sunroofcuda]
#3128263
03/10/23 09:28 PM
03/10/23 09:28 PM
Posts: 1,426 Central Pa
moparjim79
Central Pa
My 2014 300 with the 3.6L suffered a cracked oil filter housing at about 31,000 miles. It was replaced under warranty. I first noticed it one evening in our garage - smelled like a burning belt. After a couple more times, I realized it was burning oil. They were notorious for doing this - the plastic assembly would crack & allow for oil to leak & start cooking on the top of the engine. So far, this has not happened on our 2016 300, but on cold starts, there is a sound like old solid lifter engines had from the valvetrain. I've had 2 different dealers look at this & both claim the rockers are good, even though the 3.6's are notorious for this problem. I'm almost out of drivetrain warranty, I'm thinking of selling it. [/quote]
You're thinking of selling it because its going to run out of warranty? If its been a good vehicle to you and you're worried the rockers are going to fail soon, buy a top end kit for it. I think the rockers are $5 each, and you can easily check them in place for the most part.
