Re: Leaf spring advancements
[Re: Dart451]
#3127962
03/09/23 10:40 PM
03/09/23 10:40 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Do you know the current spring rate? 200 lb
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: moparacer]
#3127963
03/09/23 10:42 PM
03/09/23 10:42 PM
WHITEDART
bean town ....Ca
My theory is as stiff as possible on the front segment and soft on the rear. Kind of mimic what a ladder bar does with the front being stiff and the rear having the springs that hold up the car. All the rear segment would do is technically hold the car up. . One current thought is to mix in a set of composite Landrum on the back half which I can get in 175 lb spring rate which is a little lighter then what we currently have not to mention gets rid of quite a bit of weight
[Re: n20mstr]
#3127992
03/10/23 12:10 AM
03/10/23 12:10 AM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
just add a small plate kit ..... I know...... LMAO , im just being "that guy" Props for keeping it all motor The level your at now......info doesnt seem to come easy . As already mentioned, get with a "good" shock guy and hopefully you get some help. ALSO 235 radial cars are right at your ET level, and yes they have a power adder but some are leaf spring cars and maybe some of that info can crossover to your program. Are you data logging, and do you have rear shock sensors to see the travel as the car is going down the track?? AND ....nitrous cars dont add power down track, usually the kit is all in by .9 or less , so in reality you are pretty close to a 235 radial car There were a few 235 cars in the 90’s at Lights out. Was fun being down there watching them Stef, who many on here know , was down there with his son and his 235 Duster with gen3 power. Brand new motor, they were in the mid teens with 1.15 60 foot leaving at 30% this in 85 degree heat. On Leafs, about 75 pounds to heavy Not sure if it was Bradenton or Orlando but somebody went 4.65. I understand it’s an “ outlaw” car, not sure what isn’t legal on it, or who it was.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#3128053
03/10/23 10:23 AM
03/10/23 10:23 AM
Posts: 4,745 On the parachute mount
n20mstr
just add a small plate kit ..... I know...... LMAO , im just being "that guy" Props for keeping it all motor The level your at now......info doesnt seem to come easy . As already mentioned, get with a "good" shock guy and hopefully you get some help. ALSO 235 radial cars are right at your ET level, and yes they have a power adder but some are leaf spring cars and maybe some of that info can crossover to your program. Are you data logging, and do you have rear shock sensors to see the travel as the car is going down the track?? AND ....nitrous cars dont add power down track, usually the kit is all in by .9 or less , so in reality you are pretty close to a 235 radial car There were a few 235 cars in the 90’s at Lights out. Was fun being down there watching them Stef, who many on here know , was down there with his son and his 235 Duster with gen3 power. Brand new motor, they were in the mid teens with 1.15 60 foot leaving at 30% this in 85 degree heat. On Leafs, about 75 pounds to heavy Not sure if it was Bradenton or Orlando but somebody went 4.65. I understand it’s an “ outlaw” car, not sure what isn’t legal on it, or who it was. The car you speak of going 4.60's on a 235 , yes that is a Fox body with a Turbo BB chevy based engine, Its not follwing the 235 class rules. So really not a fair comparison that car can run 4 teens on a 275
....BAD A$$ STREET CAR.....
[Re: justinp61]
#3128104
03/10/23 12:09 PM
03/10/23 12:09 PM
Posts: 910 West Virginia
B1Frank
West Virginia
I see both side's of the story, if you want to go fast i would go with the mono-leaf, I am building a car like i was #16 years old, that is why i moved in the spring #3 inches, with the super-stock spring, it was around then. that is a good point !
[Re: n20mstr]
#3128134
03/10/23 01:16 PM
03/10/23 01:16 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
They legged it out on the last day of Sick Week to go 7.1X@206 or something dumb on a 235 tire lol.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3128149
03/10/23 01:51 PM
03/10/23 01:51 PM
Posts: 2,905 Pattison Texas
CSK
Pattison Texas
As Dragula said, get the calver sliders, they are made at an angle & will give you more axle drop, or something like these ???
[Re: CSK]
#3128205
03/10/23 05:01 PM
03/10/23 05:01 PM
WHITEDART
bean town ....Ca
I did purchase a set of those just not sure I want to go to that
[Re: WHITEDART]
#3128210
03/10/23 05:34 PM
03/10/23 05:34 PM
Posts: 668 IL
Dart451
IL
Do you know the current spring rate? 200 lb So you could calculate from that. How many inch's do they compress at ride height? What's the front and rear spring segment lengths?
[Re: WHITEDART]
#3128299
03/10/23 11:55 PM
03/10/23 11:55 PM
WHITEDART
bean town ....Ca
Hollow 7075 saved a few ounces on each side
[Re: WHITEDART]
#3128391
03/11/23 12:16 PM
03/11/23 12:16 PM
Posts: 2,541 PA
moparacer
PA
Hollow 7075 saved a few ounces on each side Sweet! Just as long as it can handle the stress they see at launch and not flex or bend. I bet its is pretty high.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: dvw]
#3128443
03/11/23 02:33 PM
03/11/23 02:33 PM
WHITEDART
bean town ....Ca
The Khouty boy's were having consistancy issues last year with their all motor car. Vince senior told them to take out the titainium 4 link bars and replace them with steel. It fixed the issue. Doug these are made out of 7075 which technically is stronger than the material that was originally used I have ran them for two events now with great success I can't say there was any Improvement but the car definitely went straight every pass
[Re: WHITEDART]
#3128478
03/11/23 04:12 PM
03/11/23 04:12 PM
Posts: 154 Canada
cuda499
Canada
Has anybody thought about changing out the rear segment on a Calvert mono leaf for more or less stored energy .. has anybody ever mixed a composite rear segment with a steel front segment I'm currently working on changing things around looking for more stored energy however the Calvert Springs just do not have very much Arch definitely not as much Arch as I would like.. the rear end currently suspends 3 inches from ride height before the car has to fight the spring as well as the shock I'd like to increase that to 5 in of free travel and maintain a relatively low stance I would get some LP racing rear leaf spring brackets, if your sticking radial, and a set of shock sensors. Do you run an ARB in the back?
[Re: cuda499]
#3128483
03/11/23 04:22 PM
03/11/23 04:22 PM
WHITEDART
bean town ....Ca
I have the second set he ever made however I haven't installed them yet no I do not run an ARB
