Re: Gen III Hemi into a Fusie
[Re: 440newport]
#3127696
03/09/23 12:11 AM
03/09/23 12:11 AM
Posts: 2,256 IL
furious70
IL
it's basically the same cost to get the nag1 or TF8 working. I would personally go late model to get the improved lifters. The different years have different FMEA mount and locations. You should study those to see what will work best for what you want to do. I tested both the car setup and later truck in my coronet. Some day I may do a gen III in my Fury. Rough measurements show the car orientation of the alt might fit and not hit the a arm. Of course now Holley also sells an expensive but useful FMEA that moves things around for conversions. The a/c compressor low slung usually hits the conversion mounts I think, not needed for my Coronet so I didn't test that but quite sure it would hit the mounts or the K member itself.
The 03-04 truck FMEA is actually the easiest to work with if you want a/c and ps from what I've seen, but the water pump design changes on an eagle I think? And you wouldn't be able to run a car intake, which is ok because the truck intakes have more tq.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Mr onetwo]
#3128011
03/10/23 01:06 AM
03/10/23 01:06 AM
Posts: 2,256 IL
furious70
IL
I would never use the truck trans either. Very goofy ratios and still big.
In that combo you get HotRodDave's high CR engine that he really likes.
392 cam is the best value in cam for sure. I have one for the eventual 5.7 in my coronet
[Re: Mr onetwo]
#3130278
03/18/23 09:21 AM
03/18/23 09:21 AM
Posts: 2,256 IL
furious70
IL
Well, my vote is in.I just ran into a 2012 5.7 Eagle in a Ram 1500. 113,000 miles, turns over easy and no metal in the oil.Comes with all the wiring and controllers for $500...not bad at all.Now I have to make a decision on the transmission, but I have plenty of time. Score!
[Re: furious70]
#3130581
03/19/23 03:11 PM
03/19/23 03:11 PM
Posts: 1,553 Michigan
Kiddart
that is a huge score!! where are these deals for me??
Thank you Kiddart
[Re: Mr onetwo]
#3132488
03/26/23 05:02 PM
03/26/23 05:02 PM
Kiddart
if you change your mind shoot me a PM i will gladly pay you what you paid.
Thank you Kiddart
[Re: Kiddart]
#3133797
03/31/23 05:35 AM
03/31/23 05:35 AM
Posts: 195 Coastal Maine
Mr onetwo
Coastal Maine
if you change your mind shoot me a PM i will gladly pay you what you paid. Sorry dude....not gonna happen
