Re: what size convertor behind a 572 Hemi
[Re: mopar dave]
#3125591
03/01/23 10:30 AM
03/01/23 10:30 AM
Posts: 4,594 Motor City
6PKRTSE
Motor City
I have a custom built PTC 9" 5600 nitrous converter behind my 528" Hemi and still street driven all over back and forth to work, go get ice cream, cruise nights, car shows etc.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#3125601
03/01/23 11:11 AM
03/01/23 11:11 AM
Posts: 2,938 A shed in England
Tig
A shed in England
What size and stall speed do you guys think i need behind my 12:1 572 Hemi street/strip deal? I have been running an 8" Dynamic 5400 stall behind my 511 12.5:1 wedge on the street without issue. I'm not afraid of stall speed and dont want to give up anything and drive it on the street. I have been told by a few that most under stall their Hemi's. Been told Hemi's n/a dont make the torque of an equal wedge, sounds like they need more stall. Not sure, what do ya think? I was using an old 8" ATi that was specified for an old 770 ish hp 528ci motor. The car ran great with the replacement 580ci wedge with 4:10 rear and we ran it for years. I recently changed from 4:10 to 3.73, stall speed increased from 5200 to 6100 and slip from 7% to 20% at the finish line. no changes to the engine, just blowing through the converter. I now have a 9.5" converter waiting to be fitted. Get a new one spec'd to your entire combo, a good converter company will usually ask for as much info available on the combo anyway. HTH's ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: mopar dave]
#3125602
03/01/23 11:18 AM
03/01/23 11:18 AM
Posts: 3,114 Michigan
A727Tflite
I'm curious, why bigger than 8" behind a 572 Hemi? What will the 9.5-10" do that the 8" can't? Just trying to learn something. Look at it like you would at a boat prop. Larger is more efficient at mid range and higher speed. The smaller converter coupling point is at very high engine speed. Not conducive to good street driving.
[Re: mopar dave]
#3125647
03/01/23 01:09 PM
03/01/23 01:09 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot depends on the torque curve and what you want to do with the car. A custom full on race converter could run a 9.5 inch core, stalled more for max et, and be loose, like 6000 stall. A car mainly driven on the street where you want a more responsive setup, might be on an 11 inch core and stall 3600. Your info provided to a good converter builder will provide him with info to build what will suit you.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: mopar dave]
#3125651
03/01/23 01:14 PM
03/01/23 01:14 PM
Posts: 12,423 Taxes & Virus's R-US, NY
Dragula
9.5 here from ATI....works very well. Interviewed a lot of convertor makers before I chose one, and very few knew what to use for a 600 cube street car...ATI had no problem.
[Re: Dragula]
#3125690
03/01/23 04:00 PM
03/01/23 04:00 PM
A727Tflite
9.5 here from ATI....works very well. Interviewed a lot of convertor makers before I chose one, and very few knew what to use for a 600 cube street car...ATI had no problem. The main difference between converter companies is the honesty and accuracy of their customers when they provide the power levels and vehicle info and the performance feedback after the converter is used. This library gets them close when they build you a converter.
[Re: mopar dave]
#3125781
03/01/23 09:21 PM
03/01/23 09:21 PM
Posts: 145 NJ
cb1289
NJ
Wait until you put the motor on a dyno and take that data to the converter guy of your choice along with a description of your car and how you plan to drive it.
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: mopar dave]
#3125802
03/01/23 10:30 PM
03/01/23 10:30 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Ok, I understand. Dynamic hit the stall I was asking for dead nuts on the 8” I have now. Gave them all my info and they gave me an excellent vert. Can drive any where and cruising the temp never gets over 180. 6% slippage at the track. So does everything well. Looking for something similar in manners. That's great. If you like what you got from Dynamic, I would contact them for their recommendation, if I were you. They may tell you to try what you have now or recommend something that's a better match.
[Re: cb1289]
#3125804
03/01/23 10:44 PM
03/01/23 10:44 PM
Posts: 712 California
BigDaddy440
California
Wait until you put the motor on a dyno and take that data to the converter guy of your choice along with a description of your car and how you plan to drive it. I also think this is wise.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
