Re: Driver train upgrades for hemi install [Re: dizuster] #3125501
03/01/23 12:36 AM
03/01/23 12:36 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I think you are right. Wouldn't break anything on the street ,but at the track, not sure. I use the M/T bracket radials and last time out at the track they were dead hooking pulling 1' wheelies til i tighten up the front shocks. Never ran a radial that hooked that good ever. It is a foot brake deal thou.
Re: Driver train upgrades for hemi install [Re: Moparrob68] #3125502
03/01/23 12:41 AM
03/01/23 12:41 AM
Mt Morris Michigan
Mt Morris Michigan
Sounds like its holding up well. My car should weight about 3300 with the Hemi and me in it. My axles are have been resplined to 35.
Re: Driver train upgrades for hemi install [Re: old_racer] #3125542
03/01/23 08:21 AM
03/01/23 08:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The trick to 1/2 studs is proper torque (100lbs) and a wheel that has enough surface area to contact the entire rotor/drum. Ran 750 passes with 1/2" studs in the high 1.2- low 1.3 60ft. Front planet carier looked bad at around 325 passes so it was swapped. The 2nd one went 400 passes when it stripped. The driveshaft is aluminum. The yokes are forged, not billet. 1350 solid Spicer u joints. The only drive train parts besides the planet it's broke are the rear wheels and 3 sets of Dana gears. It now has 5/8" studs and a steel front planet, stock trans shafts (850 passes)
Doug
Re: Driver train upgrades for hemi install [Re: dvw] #3125562
03/01/23 09:36 AM
03/01/23 09:36 AM
Mt Morris Michigan
Mt Morris Michigan
I should be fine. I think since the trans is currently behind my 511 it should have a look inside before it gets behind the Hemi and i think i'll do the steel planets just to be safe. The Strange drive shaft was purchased as a forged yoke 1350 joints shaft combo. I will step up my wheel nut torque from 80 to 100 as you suggest. Thanks guys.
Re: Driver train upgrades for hemi install [Re: an8sec70cuda] #3128863
03/12/23 09:24 PM
03/12/23 09:24 PM
pa
572charger Offline
572charger  Offline
pa
i did go in the 8s at 154mph with stock dana axles u will break the ft planetary it will rip the splines out of it my second 9 second pass did it
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
