Re: 833 HEMI overdrive conversion
[Re: fastmark]
#3124100
02/23/23 08:14 PM
02/23/23 08:14 PM
Posts: 4,212 New York
polyspheric
New York
GV is the smallest change @ 77.8% recovery, but it can be switched in & out to create intermediate ratios (1, 1½, 2, 2½, etc.).
Boffin Emeritus
[Re: Moparnut426]
#3124105
02/23/23 08:58 PM
02/23/23 08:58 PM
Posts: 5,447 So Cal
Sinitro
So Cal
I see Passion does an OD HEMI 833 conversion. Has anyone on here done it, Any pros, Cons? Not wanting to drop the coin for a 5 speed for my Demon, and honestly not even remotely interested in cutting it up to make one fit either.
Jamie quoted me 2800 ish for the gearset and parts. I can swallow that easier than buying his drop in tranny. Last year I installed a Passon Hemi overdrive in my 70 RoadRunner.. Jamie designed/tooled a new set of OD gears, much better than using an old set of gears out of another transmission. Basically its ratio are similar to the torqueflite but with an added overdrive. For my application, just cruising to neighboring car shows, but on the freeway @65 MPH with 3.91 gears the RPMs dropped down about 20% to 2600.... If one is not racing, I strongly recommend going this way... Just my $0.02...
[Re: Jerry]
#3124300
02/24/23 05:37 PM
02/24/23 05:37 PM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
why do they love the gear vendors? it does have the least amount of drop for the od. i get the very liitle to no cutting. are your customers auto guys or 4spd guys? Both of the ones that are running at the present are 3.54 Dana rear and hemi 4 speed. One guy has never had a stick car but loves the way the hemi 833 shifts and loves the rpm drop in OD. The other guy had a Tremec we installed years ago. It has always been trouble. It would not shift good at high rpm, has a terrible first gear ratio, and is noisy. He sent it off twice to have it worked on to shift better with no luck. He loves this new GV od because of the first gear ratio, final drive, it’s quite and you can shift it at high rpm. What’s not to like. I’d love to sell his POS Tremec and bell housing to get it out of my shop.
[Re: fastmark]
#3124317
02/24/23 07:15 PM
02/24/23 07:15 PM
Posts: 876 Arizona
PolyDart
Arizona
[quote=Jerry]. He loves this new GV od because of the first gear ratio, final drive, it’s quite and you can shift it at high rpm. What’s not to like I've got two GV ODs.One is behind a 390 small block, the other behind a 512 BB. Couldn't be happier.
[Re: Moparnut426]
#3124393
02/24/23 10:57 PM
02/24/23 10:57 PM
Posts: 4,463 Morristown Tn.
71birdJ68
Morristown Tn.
I have one in my RR, I like it for just cruising, but it feels kind of stiff and I don't think it would shift quick enough for racing. It's really nice for a big torque engine, as you can just stick it in OD and lug around. And on the Interstate I run with the fast cars. I would say the biggest benefit is the fact that it just bolts in with all of the stock parts and hardware, you don't have to try and figure out what part came from what other car brand if you need something.
[Re: polyspheric]
#3124522
02/25/23 02:37 PM
02/25/23 02:37 PM
Posts: 1,012 rust belt
Moparite
rust belt
Ive done all of the conversions out there, What about a 8HP70 conversion? I would choose 8 speeds including OD over a 3 speed with a GV's. These where put behind the hellcats so they will just about handle anything you put in front of it. link This is another option.
[Re: Moparite]
#3124543
02/25/23 03:35 PM
02/25/23 03:35 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Ive done all of the conversions out there, What about a 8HP70 conversion? I would choose 8 speeds including OD over a 3 speed with a GV's. These where put behind the hellcats so they will just about handle anything you put in front of it. link This is another option. The GV gives you 6 gears. Do you really need more behind a 500+ inch stroker? That 8 speed will be big $$$ by itself and then it needs a $tand alone controller that I'm not sure even exists and if it does, is it readily available. I would use the GV kit for the short tail motorhome trans to keep the overall trans length and driveline angle reasonable. I think they also make a shorty kit that uses the married 4x4 output shaft to make it a really compact installation. Kevin
[Re: Twostick]
#3124604
02/25/23 08:12 PM
02/25/23 08:12 PM
polyspheric
New York
Another GV advantage I can think of is the use of an intermediate gear (in a 727: 2½) with a street axle ratio to assure reaching max RPM in the traps, where 2nd gear is way too short and high gear would be not only too tall but too great an RPM drop. 727: 2½ shift to 3 only loses 11%, versus std. 727 2-3 shift loses 31%.
Boffin Emeritus
[Re: polyspheric]
#3124724
02/26/23 10:23 AM
02/26/23 10:23 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've never met anyone with a GV who actually splits the gears. They all did it a few times when it was a new toy but then it went right back to 3 speeds plus OD.
[Re: feets]
#3124736
02/26/23 11:12 AM
02/26/23 11:12 AM
polyspheric
New York
Of course, you only do this when you need it (as I described), it's not a toy.
Boffin Emeritus
