Re: E body 2 speed to 3 speed wiper conversion, what do I need?
[Re: second 70]
#3125440
02/28/23 09:24 PM
02/28/23 09:24 PM
Posts: 1,757 Phila
PhillyRag
Phila
I agree that it would work if you remove and rewire the plug so the wiring to the later switch is correct. But that is a change to the factory harness. Lol No change to the actual wiring harness. Just remove the brass terminals from plastic and reinsert into replacement plastic holders. No need to cut/crimp wiring. Easy to understand: you're just replacing the earlier 2 plastics with the later 1 piece. Doesn't require a degree in electrical engineering. The earlier switch is larger cause it has a rheostat built into it.
[Re: second 70]
#3125838
03/02/23 07:40 AM
03/02/23 07:40 AM
Posts: 6,445 Abilene, Texas
fastmark
Abilene, Texas
Thanks for the diaphragm, but if I am understanding this correctly, you will have to either put all these wires into individual plastic insulators or have a complete one from a 72 up wiring harness and just move all the wires? I think this would have been way over my customers head so I opted for the modified and rebuilt variable speed switch from Devinism for a little over $200 and it just plugged right into the customers new 70 harness..
[Re: fastmark]
#3125863
03/02/23 10:17 AM
03/02/23 10:17 AM
Posts: 147 Canada
EW1BH27
Canada
if I am understanding this correctly, you will have to either put all these wires into individual plastic insulators or have a complete one from a 72 up wiring harness and just move all the wires? Yes, you understand correctly. You made a good call going the K.I.S.S. method with consideration for your customer's skill level.
[Re: roadrunninMark]
#3126322
03/04/23 12:31 AM
03/04/23 12:31 AM
Posts: 1,757 Phila
PhillyRag
Phila
I think I will try to find either a 70-71 E or 67-69 A switch. I am not going to mess with the wires either. ???? It's as simple as removing a terminal front 1st plug & reinserting into the 2nd. Repeat until all are done. Never understood how many are so hesitant to do even some simple wiring tasks on a 12volt system. Now newer cars I can understand, but these older systems are simple in comparison.
[Re: PhillyRag]
#3126354
03/04/23 06:53 AM
03/04/23 06:53 AM
fastmark
Abilene, Texas
I think I will try to find either a 70-71 E or 67-69 A switch. I am not going to mess with the wires either. ???? It's as simple as removing a terminal front 1st plug & reinserting into the 2nd. Repeat until all are done. Never understood how many are so hesitant to do even some simple wiring tasks on a 12volt system. Now newer cars I can understand, but these older systems are simple in comparison. Finding a used 72 up switch and plug in may prove just as challenging. Just call up Devinism and he can fix you up with a restored switch that will fit your 70 harness and plug.
