Re: Accusump Issue ? [Re: dvw] #3124814
02/26/23 03:26 PM
02/26/23 03:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by dvw
There is no plastic line on an Accusump. Braided steel line feeds the engine. Either a fitting broke. The snap ring for the piston retainer popped out. Or the solenoid broke.
Doug
It was a joke..
Re: Accusump Issue ? [Re: Tig] #3124920
02/26/23 11:22 PM
02/26/23 11:22 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by Tig
I read somewhere else that the end plates have been known to "pop off". Not saying that's what happened in this case but has anyone else heard of that ?
I've never seen one taken apart nor can I find any pics / exploded diagrams. Are they rebuildable by manufacturer only ? Canton offers a rebuild service.
Morosos are easy to service. A large snap ring pliers is needed. I serviced/inspected mine every off season. They will collect trash.
Refill with clean oil, install, charge to prelube the engine on start up. Reset preload and go,
Re: Accusump Issue ? [Re: Tig] #3124927
02/26/23 11:42 PM
02/26/23 11:42 PM
montana
BANDIT Offline
BANDIT  Offline
montana
And to think, all these years, we filled the tank full of 4 tubes of valve lapping compound, couple quarts of oil, with a manual ball valve, that the driver could open up in the claiming area, after someone claimed our motor! But that was IMCA Racing. LOL. Was sure and eye opener the next day during hot laps!
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
