71 Fenders on a 70 Barracuda #3123249
02/21/23 06:09 AM
02/21/23 06:09 AM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Will 1971 Barracuda Front Fenders fit a 1970 Barracuda? I wanted to rplace mine with the 71 gill type fenders.
Re: 71 Fenders on a 70 Barracuda [Re: Chip] #3123256
02/21/23 08:14 AM
02/21/23 08:14 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
yes they will bolt on. been done many times.
you will also need 71 grill and related parts. the 70 grill won't work, 70's had 2 headlights 71 has 4.
you will have to cut out the headlight mounting parts and switch them between the fenders. i THINK this will work. the edge of the fender that meets the grill might be different.
you COULD buy gilled patch panels and weld them in your 70 fenders. i think they still sell this part.
perception is 90% of reality
Re: 71 Fenders on a 70 Barracuda [Re: Chip] #3123281
02/21/23 09:59 AM
02/21/23 09:59 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 1970 fenders look the best.
Re: 71 Fenders on a 70 Barracuda [Re: Alaskan_TA] #3123304
02/21/23 11:05 AM
02/21/23 11:05 AM
GA
roadrunninMark Offline
GA
It would be easier and probably cheaper just to weld in the gill patch panels then having to replace the entire grille section (or cut out to 2 headlights)... Here is the link for them.. https://www.beaparts.com/item_detail.aspx?id=576
Re: 71 Fenders on a 70 Barracuda [Re: roadrunninMark] #3123447
02/21/23 04:07 PM
02/21/23 04:07 PM
IL us
I
ink Offline
ink  Offline
I
IL us
^^^^^^^^what I did ^^^^^^^^^^
