Re: plastic engine blocks
[Re: rickraw]
#3123451
02/21/23 04:16 PM
02/21/23 04:16 PM
Posts: 12,307 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Make up a block out of cardboard, should get u close enough. Now you're stealing speed secrets from guys who put an LS in their Fox bodies.
[Re: A727Tflite]
#3123595
02/22/23 08:45 AM
02/22/23 08:45 AM
Posts: 4,132 Mo.
racerx
Mo.
i dont need to mount anything to the block, just need it for mastercylinder clearance and pass inner fender clearance. Why can’t you just lay the Hemi heads on a 440. Doesn't the hemi and a 440 have different deck heights?
[Re: racerx]
#3123603
02/22/23 09:41 AM
02/22/23 09:41 AM
Posts: 3,176 Michigan
A727Tflite
i dont need to mount anything to the block, just need it for mastercylinder clearance and pass inner fender clearance. Why can’t you just lay the Hemi heads on a 440. Doesn't the hemi and a 440 have different deck heights? Same. So is the 413, 426 wedge.
