Re: Cheap stock stroke 400 makes 530 HP?
[Re: justinp61]
#3121968
02/16/23 10:21 AM
02/16/23 10:21 AM
Posts: 4,704 Wichita
GY3
Wichita
The part 2 of this video is up where he bolts on a ported tunnel ram.
I'm anxiously awaiting the Street Dominator part 3 installment.
[Re: rickseeman]
#3121998
02/16/23 11:50 AM
02/16/23 11:50 AM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
He had a small block in his 68 Barracuda bracket car. He built this 400 to go in it. And yes, he's 1/8 mile in Arkansas. Aha, thanks for that. That's not the dude I was thinking of, then. The youtuber I was thinking of had either a Dart or a Valiant, and his test track was something like 800 feet or other odd length.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3122125
02/16/23 05:48 PM
02/16/23 05:48 PM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have speculated that any 400 using a 3.52 stroke crank would be a very good match for a torqueflite equiped bracket car. The short stroke will allow consistancy , yet at up to 426(!!) Cubes still make serious power, enough for a 10.00 et 3300 lb car. Easy to drive, as dhifts won't be too soon on the 1/2 given a good gear choice.
[Re: gregsdart]
#3122134
02/16/23 06:33 PM
02/16/23 06:33 PM
Posts: 554 Kentucky
clovis
Kentucky
Dwayne Porter did a pretty straight forward 383 that made 500 hp. I have been able to duplicate it and it makes for a great 7.00/11.00 combo at #3400. However, I would that say that due to parts availability I'm not sure I would build another 383 but move in the direction that has already been mentioned- 400 based 4.375 bore/6.800 rod/offset ground 383 crank. http://www.moparts.org/Tech/Archive/bb/25.html
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: 375inStroke]
#3122343
02/17/23 02:16 PM
02/17/23 02:16 PM
Posts: 201 PA
Scully
PA
With big block strength, and a stroke shorter than a 350 Chevy, how can these things not rev to the Moon? How high it revs will depend on the head flow and induction along with cam design. The short stroke and long rod ratio make the 400 gentle on it's guts at high rpm's even with heavy pistons and rods. Given the same basic induction and cam a small bore long stroke 59 383 (4.03 x 3.75) will rev higher than a .030" over, stock stroke 400 before it runs out of air, it's the overall cubic inches that draw a given amount of air, not the stroke.
[Re: Scully]
#3122359
02/17/23 03:05 PM
02/17/23 03:05 PM
GY3
Wichita
It's fun to see a Mopar build out-perform what people think it should be making.
I see all these high dollar Indy Cylinder Head builds that Indy puts on it's Facebook page and it seems like they are all underperformers.
[Re: GY3]
#3122476
02/18/23 01:27 AM
02/18/23 01:27 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
It's fun to see a Mopar build out-perform what people think it should be making. I agree.
2011 Drag Pak Challenger
[Re: Dragula]
#3122556
02/18/23 03:06 PM
02/18/23 03:06 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
We made that much with an Eddy Head 340+.030 mild street engine. Now that I must see to believe
[Re: 70VcodeCoronetRT]
#3122826
02/19/23 02:16 PM
02/19/23 02:16 PM
rickseeman
Stuttgart, Arkansas
justmoparjoe did a dyno test recently as a part of this series on the Edelbrock RPM Performer but the Holley Street Dominator had a lot more power.
#3122880
02/19/23 06:01 PM
02/19/23 06:01 PM
Posts: 1,543 USA
hudsonhornet7x
USA
My favorite motor build I have even done is my 400 based 470. It's a mild street build. Ported eddys by D Porter, .540ish hydraulic roller, RPM Performer. That little motor is surprisingly a little powerhouse. RPMs like a small block. I would love to do a current version. With 240 Trick Flows and a little more cam. I am building a 470 now with trick flow 270's and a mechanical flat tappet. I hope it works well.
[Re: rickseeman]
#3123036
02/20/23 11:12 AM
02/20/23 11:12 AM
GY3
Wichita
justmoparjoe did a dyno test recently as a part of this series on the Edelbrock RPM Performer but the Holley Street Dominator had a lot more power. Those Holley Street Dominators work way better than most people realize and have the advantage of fitting under most stock hoods.
[Re: GY3]
#3123090
02/20/23 03:09 PM
02/20/23 03:09 PM
ZIPPY
S.E. Michigan
I see all these high dollar Indy Cylinder Head builds that Indy puts on it's Facebook page and it seems like they are all underperformers. While I have to agree the numbers on alot of them don't make them appear to be world beaters, some of those have been pretty helpful and encouraging since there was really nowhere else to find anything like a dozen 572 Hemi builds intended for the street, with really deliberate compromises, to study and then go talk to the builder about at a show. I'd thanked Kenny for putting more specs out there on the magical book of faces, as it helps guys like me out quite a bit... and he said it was Indy ownership's idea, they wanted no secrets... which is a very different business strategy than alot of others doing Hemis.
Rich H.
Esse Quam Videri
#3123208
02/20/23 10:59 PM
02/20/23 10:59 PM
Posts: 4,959 WI
Dcuda69
WI
My favorite motor build I have even done is my 400 based 470. It's a mild street build. Ported eddys by D Porter, .540ish hydraulic roller, RPM Performer. That little motor is surprisingly a little powerhouse. RPMs like a small block. I would love to do a current version. With 240 Trick Flows and a little more cam. I did a similar street build using OOTB Eddy heads and a street solid roller. !0.2:1 compression.Same intake and a Holley 800. I always say...it RPMs like a chainsaw and pulls like a freight train. It made 425 whp at 5500(could have easily spun to 6500) and over 500 ft lbs all the way up there. It lives in my 69 B'cuda with a 4 speed and 3:73s. Thing's a blast to drive!
[Re: Dragula]
#3123227
02/21/23 12:07 AM
02/21/23 12:07 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
I've been watching justmoparjoe do a stock stroke 400 build on youtube. Nothing special, 10:1, E-Street heads, Holley intake, 850 cfm Holley. He took it to the dyno and it made 530 HP? I was impressed. This is the dyno episode but the whole build is on there somewhere. https://www.youtube.com/watch?v=cEHE-_Zho-M&t=2s We made that much with an Eddy Head 340+.030 mild street engine. Care to share the details on your 340 build? What cam did your run?
[Re: hudsonhornet7x]
#3123318
02/21/23 11:42 AM
02/21/23 11:42 AM
Posts: 1,706 Nebraska
70VcodeCoronetRT
Nebraska
My favorite motor build I have even done is my 400 based 470. It's a mild street build. Ported eddys by D Porter, .540ish hydraulic roller, RPM Performer. That little motor is surprisingly a little powerhouse. RPMs like a small block. I would love to do a current version. With 240 Trick Flows and a little more cam. I am building a 470 now with trick flow 270's and a mechanical flat tappet. I hope it works well. You will love it!!!!
[Re: justinp61]
#3123350
02/21/23 12:48 PM
02/21/23 12:48 PM
Posts: 28,620 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I'd like to see the recipe for that one too. Make that 3
[Re: 340SIX]
#3123651
02/22/23 12:29 PM
02/22/23 12:29 PM
Posts: 4,791 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Calling this build Cheap is not accurate although compared to a full on race engine I guess that would be so. One big staple of an affordable build is the cam and lifters. The option of reliable flat tappet cam and lifter sets is pretty much gone which is a shame. Back in the day- all those differing affordable grinds from competing manufacturers and their quality was superb.
Keep old mopars alive.
