Page 22 of 23 1 2 20 21 22 23
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3104159
12/20/22 11:20 PM
12/20/22 11:20 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
"Wild Willie" Borsch
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3104160
12/20/22 11:27 PM
12/20/22 11:27 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3104162
12/20/22 11:34 PM
12/20/22 11:34 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Raise your hand if you remember times like this. up I wish I had a camera handy back in the day hanging out with my buddies doing stuff like this.
But how many of us actually thought about that then? Very few, that's how many. frown We were too busy having a great time, enjoying the moment.
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3104257
12/21/22 01:41 PM
12/21/22 01:41 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
not having an "engine stand", we used two 55 gallon drums with a couple of pieces of [real measurement] 1/2" plywood bolted together to get the engine to a comfortable work height.
with block upside down, put the crank in. turn block on it's end and use whatever wood shims would lift the block enough to allow the crank to turn, or stick crank snout through hole in plywood and shim front of block to steady it. install pistons, oil pump & pickup [or just pickup if big block] etc, then oil pan.
flop block right side up and shim with 2x4's to keep steady, then assemble rest of engine.
when done, roll "gym set" over engine to lift from drums. other methods used to lift engine included chain blocks, fork lift, bucket truck, wrecker, etc, depending upon where engine was being assembled.
and we weren't afraid to put one together outside with the wind blowing. biggrin
beer
Re: 1960s-1970s Drag Racing Pix [Re: moparx] #3104295
12/21/22 04:09 PM
12/21/22 04:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
beer
And I'll bet that those motors assembled outside in the wind live forever, HUH work whistling
That is one of the lessons many people have wish they had learned that lesson by advice or watching someone else make that mistake work shruggy
Re: 1960s-1970s Drag Racing Pix [Re: Cab_Burge] #3104358
12/21/22 08:59 PM
12/21/22 08:59 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: 1960s-1970s Drag Racing Pix [Re: B Dartman] #3104379
12/21/22 09:52 PM
12/21/22 09:52 PM
Originally Posted by B Dartman
Dude, is this a perfect example of "shade tree mechanics" at work? wrenchwhistling grin
Re: 1960s-1970s Drag Racing Pix [Re: Cab_Burge] #3104545
12/22/22 12:00 PM
12/22/22 12:00 PM
moparx Offline
moparx  Offline
beer
surprisingly, those engines lived a long and hard life at my junkyard. biggrin
one was for a 350 cat dozer, and the other was for an international boom truck.
not the correct way of doing things for sure, but back then, we did what we had to do, where it needed to be done.
today, we know better, but i'm sure there are other examples all over the world that have had rebuilds done outside that have lived a surprising life span.
remember the old saying : "kiddies, do as i say, not as i do !" laugh2
beer
Re: 1960s-1970s Drag Racing Pix [Re: moparx] #3106956
12/31/22 01:09 PM
12/31/22 01:09 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
[Linked Image] [Linked Image]
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3107074
12/31/22 07:43 PM
12/31/22 07:43 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3107075
12/31/22 07:45 PM
12/31/22 07:45 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3107077
12/31/22 07:47 PM
12/31/22 07:47 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3107082
12/31/22 08:19 PM
12/31/22 08:19 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3107087
12/31/22 08:52 PM
12/31/22 08:52 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3107167
01/01/23 09:25 AM
01/01/23 09:25 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Back when "Bumper Jacks" ruled...... Those of us that had/used them probably experienced brief moments of fear laying under the car when it would start to tip over - with luck a quick foot or hand could steer it back on center
Re: 1960s-1970s Drag Racing Pix [Re: B Dartman] #3107174
01/01/23 09:56 AM
01/01/23 09:56 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Those bumper jacks eek i do remember.
Re: 1960s-1970s Drag Racing Pix [Re: racerx] #3107402
01/02/23 12:52 AM
01/02/23 12:52 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
O.G.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1960s-1970s Drag Racing Pix [Re: BloFish] #3109188
01/05/23 08:56 PM
01/05/23 08:56 PM
New Jersey
Qwik426 Offline OP
Qwik426  Offline OP
New Jersey
Re: 1960s-1970s Drag Racing Pix [Re: Qwik426] #3109625
01/06/23 11:57 PM
01/06/23 11:57 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Dig the timing of the shot of the Wayne County Dart (#3107082). The clutch has been released, and the rear suspension has reacted. The tires have wadded up and rotated just a bit, but the front suspension has not begun to rise. I'd bet the bottom yellow is still lit.
Re: 1960s-1970s Drag Racing Pix [Re: Greenwood] #3110176
01/08/23 07:35 PM
01/08/23 07:35 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
