440 water pump housing swap #3117370
01/28/23 10:07 PM
01/28/23 10:07 PM
NH
N
NHCharger Offline OP
N
NH
I currently have a 1977 440 block in my Daytona clone, after multiple issues I have purchased another 440. The new engine has a build date of 1968, so the inlet and outlet on the water pump is the reverse of my current motor. Can I just swap the water pumps so the water pump outlets line up with the connections on my radiator? Really don't want to modify the radiator. It's a Wizard Cooling aluminum radiator.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: 440 water pump housing swap [Re: NHCharger] #3117371
01/28/23 10:08 PM
01/28/23 10:08 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
YES..SAME BOLT PATTERN
Re: 440 water pump housing swap [Re: NHCharger] #3117856
01/31/23 10:05 AM
01/31/23 10:05 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
yep.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
