Page 2 of 6 1 2 3 4 5 6
Re: 'new' engine [Re: Al_Alguire] #3114174
01/18/23 01:17 PM
01/18/23 01:17 PM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
Originally Posted by Al_Alguire
Just cause here is some pushrod pics on my Predator junk we are still trying to finish up. Hemi block Predator stuff takes a bit more work to get clearance for sure. Supposed to be a "better" version, but not seeing it.
The Predator has some nice features that include what is overlooked when you consider 'horsepower potential' any given cylinder head has. It was hard to take those off and put on the lowly -1 stuff.
Re: 'new' engine [Re: Al_Alguire] #3114318
01/18/23 09:27 PM
01/18/23 09:27 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
the pushrod to lifter Clearnce looks a little scary Al
Re: 'new' engine [Re: boatracer572] #3114478
01/19/23 12:50 PM
01/19/23 12:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
It is close for sure, but can slide a piece of paper in there laugh2 The picture makes it look much closer than it is, should be plenty of room there but time will tell for sure. Consequences of a big pushrod and a tie bar lifter. Should have gone to a keyway deal but this is just a bracket engine. Not anything crazy for sure.
Re: 'new' engine [Re: HardcoreB] #3115026
01/21/23 12:03 AM
01/21/23 12:03 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted by HardcoreB
Originally Posted by Jeremiah
That's a rowdy looking group of gearheads right there.
The valve covers are a classic institution of the 1970's Direct Connection catalog. While I am sure they won't be used in the final rendition you see them on some bery successful race cars in old pictures.
I really dig that roller lifter lash tool. Can you put some simple blue prints on a napkin and post it?
I think the "just have fun" approach is healthy. Not being the competitive type my time at the track is more of a social event. If racing goes okay that is a bonus lol. Days off of work shouldn't be successful!
Moving forward,.you really need to get aluminum valve covers and trim those studs before dvw does something crazy like install a fiberglass hood. : D
Anything you can seat the lifer on ‘square’ this has 2 surfaces that locate. Having an ‘adjustable’ seat makes it modular for other lifters. Then mount a high resolution indicator in a way that pics up the centerline of the wheel and then pry the wheel to gage lash…verify it repeats and viola! He’s using old school M/T aluminum covers with a -12 vacuum fitting welded in place. Some of the stuff in pic was to ship it.
Thank you for the instructions. I will post a pic or two of what I come up with.
Re: 'new' engine [Re: Jeremiah] #3115092
01/21/23 11:37 AM
01/21/23 11:37 AM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
Awesome seeing the progress! Think you'll have it together in time for the May 5th heads up race at Milan?
Re: 'new' engine [Re: Blusmbl] #3115637
01/23/23 11:55 AM
01/23/23 11:55 AM
Shelby Twp. Mi
Shelby Twp. Mi
That's the plan, much to do!
Re: 'new' engine [Re: HardcoreB] #3115693
01/23/23 02:23 PM
01/23/23 02:23 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I love the old DC valve covers, but then again I'm pretty hopeless in that regard. Very confident it will be a screamer, whichever combination is chosen.
Rich H.
Esse Quam Videri
Re: 'new' engine [Re: HardcoreB] #3116805
01/26/23 05:07 PM
01/26/23 05:07 PM
PA
Harry's Taxi 2 Offline
PA
More mock-ups, more 'problems'...
Could you explain why you used the insert verses a heli-coil?
Thank You
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 'new' engine [Re: Harry's Taxi 2] #3116967
01/27/23 10:02 AM
01/27/23 10:02 AM
Shelby Twp. Mi
Shelby Twp. Mi
Thank You
In a word, that insert is more robust than a heli-coil. I left it up to the person that machined the head to make the call on what to use. From what i have HEARD the threads tend to rip-out when using no insert and just tapping the aluminum. So while a guy is here, may as well put something in there.
Re: 'new' engine [Re: HardcoreB] #3117017
01/27/23 12:26 PM
01/27/23 12:26 PM
Shelby Twp. Mi
Shelby Twp. Mi
To minimize the confusion on a few posts. This was my old engine BEFORE REPAINTING by Gdemon, reconfigured mechanically from the way i used it in a few ways. These are the valvecovers he is using.
Re: 'new' engine [Re: HardcoreB] #3117046
01/27/23 01:24 PM
01/27/23 01:24 PM
PA
PA
Thank You
I have always heli-coiled pretty much everything aluminum (and even some old Stage 5 cast iron) but after seeing your pictures i got to thinking maybe heli-coils weren't always the way to go. i have both types on hand.
Thank you for the reply.
Re: 'new' engine [Re: Harry's Taxi 2] #3117053
01/27/23 01:37 PM
01/27/23 01:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did the same thing as Sean with inserts. Actually Time-Serts. The reason for doing mine was to move the T&D bed plate outward .060" towards the valves. Since the Time-Sert is a larger diameter it made sence. The holes were offset bored. Then the inserts were able to be installed with no welding of te original holes.
Doug
Re: 'new' engine [Re: dvw] #3117092
01/27/23 03:15 PM
01/27/23 03:15 PM
Shelby Twp. Mi
Shelby Twp. Mi
Doug
So just for clarity here, I'm not sure where Doug's heads were initially machined (on what centerline) but if you move MINE, TOWARDS THE VALVE, it crashes the pushrod into the head! I'm just clarifying for anyone who might convert their heads to paired rockers with bolt-down stands. I can tell you we are using the same lifter seat height. A taller lifter seat would move the pushrod away from the head. ANOTHER VARIABLE is if the rockers had a different pivot but had the same ratio. But we also have the same rocker bodies! I can only assume with confidence that my original point of reference was on the same plain as the factory holes used for the original 5 'pedestal' holes. your results may vary lol
Re: 'new' engine [Re: HardcoreB] #3117151
01/27/23 08:40 PM
01/27/23 08:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine were mounted in the original plane. Some of the original holes were just drilled deeper. When we moved them .060" toward the valve they only required minor trimming for the pushrods.
Doug
Re: 'new' engine [Re: dvw] #3117250
01/28/23 11:09 AM
01/28/23 11:09 AM
NC
440Jim Offline
440Jim  Offline
NC
On my B1 heads, with T&D paired (5/8 shaft) rockers, I had to enlarge the pushrod holes away from the valves. Scott Koffel told me ahead of time this is needed, but not with the long single shaft rocker system.
Re: 'new' engine [Re: 440Jim] #3117658
01/30/23 09:15 AM
01/30/23 09:15 AM
Shelby Twp. Mi
Shelby Twp. Mi
Not sure what some of this has to do with the price of tea in China!? I can tell you on these heads now, with this cam, lifters, pushrods, 1.6 pivot/1.7ratio TD rocker system and 5.344 valve length with an .080" lash cap the centerline for the rocker bar hold-downs needs to move some away from the valve to allow for more lift. Getting the sweep adjusted optimal, moves the pushrod further into the head AND BOLT/STUD besides all that moving the centerline towards the valve compromises the angularity on the backside of the rocker. I'm probably sweating nothing here? but with open loads over 1000lbs and rpm over 8000, it isn't going to be a bracket build from my perspective.
Re: 'new' engine [Re: HardcoreB] #3117702
01/30/23 12:41 PM
01/30/23 12:41 PM
Shelby Twp. Mi
Shelby Twp. Mi
To clarify "Getting the sweep adjusted optimal" is done in this case, by milling the rocker bar pad down further. So, it "...moves the pushrod further int..."
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3160456
07/18/23 08:58 AM
07/18/23 08:58 AM
Shelby Twp. Mi
Shelby Twp. Mi
Having two different 'near-ready' (piston-rod-head-intake) combos to consider, I choose the one that would be the fastest to commission. I'm using 440-1 Indy's which Jeff CNC'd many years ago, this is using a used flat-top piston (DVW) that was designed for a 4.500 bore and now this KB block is 4.5065. Line2Line is currently coating the skirts and I had Rebco add vertical gas ports to pistons which had lateral ports already. I have to mention Rebco was great to me again, turning them out hours after getting them on the same day! And he's 'cheap'. Scott Brown cut me a new 55mm 4/7 swap cam with about .840" NET lift intake, he's still around and has been helpful as always. Isky also turned around my lifters quickly and reasonable, they are .937 bearing/ .850 wheel offset intake which is a BBC spec lifter body, PICS previous in this thread. I am reusing the 2x4150 (thumper) Indy T/R, Jesel drive and complete dry-sump oil system from my last engine. I had a local machinist friend remachine the pedestal area to make the best rocker geometry I could using the parts I had which are 1.60 pivot 1.7 TD paired rocker system. I had to tickle the heads spring seat about .010 to get .065 from coil bind. My spring loads are marginal light 340/850 and am using titanium 2.25" intake valves. They have about .060 P-2-V with checker springs on the intake and .100 exhaust. I have .045 piston to head cold. Manton is currently making the pushrods 7/16x.168 with a taper at the lifter end to clear the offset lifter body. My block is o-ringed so i surgically removed the SS orings (DIFFICULT!!!) and am currently installing copper then filing down flush to fill the cavity. I hope to make enough HP to run near the chassis cert (8.50) @ 2825lbs when everything is right.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3160458
07/18/23 09:19 AM
07/18/23 09:19 AM
Shelby Twp. Mi
Shelby Twp. Mi
In an act of desperation I put a request for a 55mm thrust bearing on FB and Jim Clarke (aka TS3103) came thru the next day so i could do some mock-up work. Thanks JIM!
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3160459
07/18/23 09:24 AM
07/18/23 09:24 AM
Shelby Twp. Mi
Shelby Twp. Mi
Used a SBM hub to position the 'zero' where i could use it and made a new pointer.
