Re: 'new' engine UPDATES 440-1cnc
[Re: HardcoreB]
#3160469
07/18/23 10:13 AM
07/18/23 10:13 AM
Posts: 16,925 NC
440Jim
NC
Manton PR 'example' and B1 piston modeling So I take it the B1 piston valve reliefs will work with your Indy 440-1 heads? Did you take a picture of the clay after turning the motor over?
[Re: moparx]
#3160856
07/19/23 09:01 AM
07/19/23 09:01 AM
Posts: 4,049 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
at least your guard doggy isn't asleep........... a question though, why a small block damper on a big block, although you have the timing mark where you need it. was the reciprocating assembly balanced using that damper, or are the damper weights the same [or close enough] to be able to be swapped ? just trying to learn something here. It's a neutral balance damper...i just wanted to locate the ZERO in a visible place.
[Re: HardcoreB]
#3160965
07/19/23 12:32 PM
07/19/23 12:32 PM
Posts: 19,408 north of coder
moparx
at least your guard doggy isn't asleep........... a question though, why a small block damper on a big block, although you have the timing mark where you need it. was the reciprocating assembly balanced using that damper, or are the damper weights the same [or close enough] to be able to be swapped ? just trying to learn something here. It's a neutral balance damper...i just wanted to locate the ZERO in a visible place. thank you sir.
[Re: HardcoreB]
#3180522
10/03/23 10:21 AM
10/03/23 10:21 AM
HardcoreB
Shelby Twp. Mi
More diff ways to skin a cat, I use 2 of the upper row head bolts to anchor the head to bench and use the typical in-car jesel spring tool. Also tailored the rocker bar bolts to length on the lathe.
