Re: Well I just jinxed myself big time...
[Re: Rhinodart]
#3112069
01/15/23 10:08 AM
01/15/23 10:08 AM
Posts: 10,654 Freeport IL USA
poorboy
Freeport IL USA
Its hard to say since the trans was under a load pulling a trailer,. but on my 49, I blew that trans cooler line off twice and ran it out of fluid about 3 months apart (I've redone the lines this last time) and it still works. Both times for me the trans was cold, having just started it after it had sat for several hours. Once the fluid level get below the filter, the trans quits functioning, and that happens pretty fast when a cooler line blows. Once the fluid flow stops, all the internal pressures go to zero instantly. The only damage that can happen is during the time between the full fluid and no fluid, maybe a few seconds. I would think mostly the hot parts loosing the fluid flow are mostly what would be damaged, but as soon as the pressure drops, nothing should be under load.
The cooler line has to be repaired either direction. if you take that expense away, how much dos it cost to take the chance? It does have a lot of miles on it, but do you feel comfortable with the place its at rebuilding or replacing the trans?
Fix the line, and dump $100 of fluid in it might work for a long time, or it might get you someplace you know and trust better, or you may have wasted $100. If your really concerned, forget the filter change (if it adds that much to the cost of taking a chance) you can do that at a different time. I suspect you have probably wasted $100 before on something. Put it in proper perspective.
[Re: Rhinodart]
#3112085
01/15/23 11:19 AM
01/15/23 11:19 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I should have been a factory transmission tester. Found out a trans line came off, just gotta find out if there is any damage from driving it off the highway a mile with no fluid in it. Could the existing thermistor temperature sensor be relocated to a place where it would serve the dual purpose of warning of too low ATF level? My historical experience with traditional float liquid level switches is bad. I eventually found through expensive trial and error that “level tape” sensors worked most reliably in turbulent gritty liquids. These are sealed “tape worm” looking devices where the flexible cover gets squeezed by the outside liquid, which electrically shorts out a long resistor sealed and isolated from the bouncy hot, gritty, corrosive liquid. The salesman who gave me the first level tape to try bragged that “ If the Three Mile Island Nuclear Plant had used these level sensors its core would not have overheated.”
[Re: Rhinodart]
#3112686
01/16/23 09:05 PM
01/16/23 09:05 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
[quote=Satilite73] "A goat must be sacrificed on a mountain top." What does Pontiac have to do with all this? He has already pre-sacrificed a firebird in a flaming garage sacrifice, doesn't that cover the goat sacrifice? [/quote All that did was piss off the wife. She didn't think it was funny when I said she had a true FIREbird... ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif) They told me $350 for a filter change at the dealer that is installing the lines and the mechanic thought it would be a waste of time and money if the trans is indeed smoked... How do they justify $350 to drop the the pan and change the filter??? Kevin Over $100 for trans fluid, who knows how much for a filter through a dealer plus the gasket, doesn't matter if it has anything in it or not. I am sure the labor is $150 on the schedule... It needs $100+ in fluid regardless and they would probably charge the same labour to pour it in so the true cost is a pan gasket and filter. Pulling the pan has the added advantage of telling you whether you need to just continue on pulling the trans. Kevin
[Re: Rhinodart]
#3114545
01/19/23 04:30 PM
01/19/23 04:30 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Well they put the lines on, filled it with fluid, and took it for a long test drive and everything worked as it should! ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) I will get it home and do the filter and fluid, and then destroy it... Or trade/sell it quick...
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: Rhinodart]
#3114631
01/19/23 08:23 PM
01/19/23 08:23 PM
Posts: 1,357 central Florida
VL21
central Florida
I will get it home and do the filter and fluid, and then destroy it... I would expect nothing less, Rhino!
It takes gasoline to interest me.
[Re: Rhinodart]
#3114681
01/19/23 11:08 PM
01/19/23 11:08 PM
poorboy
Freeport IL USA
Well they put the lines on, filled it with fluid, and took it for a long test drive and everything worked as it should! ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) I will get it home and do the filter and fluid, and then destroy it... I bet that broke the dealership's heart! ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I suspected that would be the outcome. A long run on low fluid would probably be a different story because the trans slowly looses pressure and heat builds, but a fast dump like a cooler line breaking drops the fluid pressure pretty much instantly. Good to hear you get to kill the trans on your own terms! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Rhinodart]
#3114736
01/20/23 07:25 AM
01/20/23 07:25 AM
Posts: 8,162 USA
360view
USA
Well they put the lines on, filled it with fluid, and took it for a long test drive and everything worked as it should! ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) I will get it home and do the filter and fluid, and then destroy it... That is good $ news. Considering all that has gone before transmission wise, consider spending modest $ to “watch over” the health of that particular transmission. Would it be crazy to buy one of those “back up cameras” but put it under the truck aimed at the trans, or trans+engine? water and grit splash might present challenges Maybe hire a trans-woman AND trans-man to say daily prayers for the life and health of your trans. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: Rhinodart]
#3116183
01/24/23 09:53 PM
01/24/23 09:53 PM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I feel bad for Jim as he broke down on the way to a transport pick up for me. But he delivered my truck exactly when he said he would and communication was always immediate. Thank Jim!! (I'm the bald guy)
Keep old mopars alive.
[Re: 2boltmain]
#3116224
01/25/23 12:06 AM
01/25/23 12:06 AM
Posts: 43,641 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I feel bad for Jim as he broke down on the way to a transport pick up for me. But he delivered my truck exactly when he said he would and communication was always immediate. Thank Jim!! (I'm the bald guy) My beard gets whiter by the transmission... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: moparx]
#3116460
01/25/23 03:59 PM
01/25/23 03:59 PM
Rhinodart
Rhinotruck
Rhinotruck
[quote=2boltmain]I feel bad for Jim as he broke down on the way to a transport pick up for me. But he delivered my truck exactly when he said he would and communication was always immediate. Thank Jim!! (I'm the bald guy) My beard gets whiter by the transmission... you should be the bald guy Rhino ! my hair falls out by the clumps when i have to deal with stressful conditions i can't solve. ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif) but being 70 years old may have something to do with it ? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) ..... ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif) [/quote I have hair for days, but my sister is losing her hair...LOL..
A-Body's RULE!
[Re: moparx]
#3116579
01/25/23 10:27 PM
01/25/23 10:27 PM
poorboy
Freeport IL USA
The amount and color of hair is way to high of concern to way too many people (says the guy that is loosing his gray hair at a pretty fast pace).
I had a bald guy with a very gray beard tell me that being bald was a sign of having a perfect head that shouldn't be hidden, and gray hair was a sign of wisdom.
I believe the gray hair is caused by children, I've never seen anyone that had (or were near) children that their hair didn't start turning gray soon after. Loosing hair is caused by being married (or trying to be). Some say both traits are natural, but I don't believe them.
Oh yea, the transmission... Change the filter, the fluid, and adjust the bands. My transmission (RE46) with only 44K miles on it had a pretty clean pan, but the filter was getting dirty already and the magnet had a little fuzz on it. I changed both about 1,000 miles after the cooler line failure transmission flush. I added a trans pan drain plug at that time as well.
