Re: Any guesses on Horsepower before the dyno?
[Re: 440Jim]
#3129158
03/13/23 08:08 PM
03/13/23 08:08 PM
Posts: 1,545 USA
hudsonhornet7x
USA
A couple pictures as it is coming together.
[Re: hudsonhornet7x]
#3129159
03/13/23 08:10 PM
03/13/23 08:10 PM
Posts: 1,545 USA
hudsonhornet7x
USA
more
#3129160
03/13/23 08:10 PM
03/13/23 08:10 PM
Posts: 1,545 USA
hudsonhornet7x
USA
Last one
#3129161
03/13/23 08:12 PM
03/13/23 08:12 PM
Posts: 1,545 USA
hudsonhornet7x
USA
The last two pictures are sideways, does anyone know how to orient them in the correct direction? Thanks
* Thanks to Feets, who gave some good advice on orienting the pictures correctly*
#3129179
03/13/23 09:29 PM
03/13/23 09:29 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The last two pictures are sideways, does anyone know how to orient them in the correct direction? Thanks When that happens with phone pics I'll crop them a little and pop them up again. Seems to work.
[Re: Dragula]
#3129192
03/13/23 10:12 PM
03/13/23 10:12 PM
Posts: 1,545 USA
hudsonhornet7x
USA
My guess is 635hp and 570 torque.....Nice looking engine. Thank you sir. If it makes anywhere near that I will be really happy.
[Re: feets]
#3129193
03/13/23 10:17 PM
03/13/23 10:17 PM
Posts: 1,545 USA
hudsonhornet7x
USA
The last two pictures are sideways, does anyone know how to orient them in the correct direction? Thanks When that happens with phone pics I'll crop them a little and pop them up again. Seems to work. Thank you, it worked perfectly. I will remember this for the next time.
#3129223
03/14/23 05:25 AM
03/14/23 05:25 AM
Posts: 10,038 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I will take a stab at it. 650 hp at 6500 rpm. For sure it will be a fun ride. The cam you chose should give you excellent service life, making for many good years full of fun. Once built, fine tuning is all that should be done IMHO. Maybe a manifold, carb or header change, but i see this build as an excellent long term performer. The 440 i built in 1975 lasted till 2018, but was still running last i heard!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
