Re: 408 stroker build educate me [Re: RangerDan440] #310900
05/08/09 08:17 AM
05/08/09 08:17 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'm running a fairly mild 408 in my truck with a cast crank, no problem but I would definitely stud the lower end. Ive also heard that Scat has a better reputation than Eagle. Keep the cam around .500 with a mellow duration since its going in a truck.
Mine is also a Magnum engine and when I built it, intake options were pretty much limited to the MP M1 so thats what Im running; its great over 4000 rpm but Im lacking the low end punch a stroker should have; Im going with more gear when I go into the rear later and hopefully that will cure it. I believe theres an Performer intake out there now for the Magums and thats what I would recommend for an RV-style cam in a truck.
Anyway, the 408 puts my 4400-lb 96 Ram into the mid 13s with 17 mpg (518 trans) so I cant complain. You'll have fun dusting off Mustangs and Hemis.
what size cam are you running Lt. dan?
2017 Grand Cherokee Overland
Re: 408 stroker build educate me [Re: coronet1966d] #310901
05/08/09 09:42 AM
05/08/09 09:42 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Common sense is a flower that does not grow in everybody's garden
Re: 408 stroker build educate me [Re: RangerDan440] #310902
05/08/09 10:45 AM
05/08/09 10:45 AM
Clinton Twp. Michigan
coronet1966d Offline OP
i cant believe your truck weighs almost 1000lb more than mine
Re: 408 stroker build educate me [Re: Crizila] #310903
05/08/09 11:40 AM
05/08/09 11:40 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Fact is Moper Mean speed is best way ( and the norm )for measuring piston strength and durability. At peak speed there is very little stress on the piston, so just measuring at one speed ( especially peak ) tells you very little about piston/rod/crank strength. The big hurter is at TDC / BDC, when the piston is at zero fps and changing directions. Yes, it is my engine, and I have had great results 100% of the time. Anyone who limits their stroker motor to 5K should go to their room!
Again, I disagree. Peak is the maximum force the piston, pin, and rod will face. The ratings we typically read are for mean speeds, yes. that's correct. But, pistons and rods dont break (from rpm stresses) at TDC or BTD. They break when either accelerating away or slowing down to those places. Cranks dont have torsional stress, not acceleration and dont figure at all in anything other than generating the acceleration rate. In any event, hypers are a favorite of mine in strokes up to 3.75. After that, they shoudl be replaced with forged for durability. Liek anythign else, a part has a finite number of cycles before it breaks. The closer you are to the limit, the fewer cycles it can take before it breaks. Lighter pistons let the rods live. But longer strokes are a beating on cast or hypereutectic pistons. AS far as rpms.. My truck doesnt see over 3500 with its' 360. It might hit 4K with a trailer up a hill in 2nd. So the sstroker for it will have cheap hypers in it. I'm not sure where that rpm remark came from other than a narrow singular viewpoint.
Re: 408 stroker build educate me [Re: coronet1966d] #310904
05/08/09 11:51 AM
05/08/09 11:51 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
4400 isn't too bad. '79 LRE's were listed at 4000 I thought. my '96 ram SLT 5.2L, NVG3500 5 speed, 2wd 8' bed was 4700 w/1/2 tank of gas when I weighed it (without me).
had PS/PB/PW/PL A/C and some heavy 17x8 cragar SS's with 275/60R17's on it.
Re: 408 stroker build educate me [Re: moper] #310905
05/08/09 08:47 PM
05/08/09 08:47 PM
Az
Crizila Offline
Crizila  Offline
Az
Apologize for the RPM remark moper - obviously that wasn't necessary. I probably am pushing the hi side of the envelope for my combo, but I think i'm still in the safe window. Some times I fall pray to the "happyness is a low ET" syndrome and lose sight of my original build goals - usually results in broken stuff. There is a lot of dynamics going on with the crank, rods & pistons that make the topic wide open for discussion. All these components don't see max stress at the same time during a 720 degree 4 stroke cycle. I happen to like and use my mean speed example and so far so good. I'm sure eventually I will break stuff - through fatigue, over stressing, what ever. Thats what mechanical things do. Just hoping it doesn't happen - tomorrow.
Fastest 300
