Re: ARP L19 rod bolt torque
[Re: mopar dave]
#3111087
01/12/23 08:41 AM
01/12/23 08:41 AM
Posts: 9,856 MI, usa
dvw
MI, usa
I use this gauge. You have to wiggle it around a little to find your number. I measured a few rod bolt lengths and made a standard with drilled ends that mimic the bolt divets. This standard is marked top/bottom. Set the gauge to zero on the standard. Measure all the bolts 1st. Then you will know how they compare. Some will be longer, some shorter. Add you stretch figure to the measured numbers. Write all the measurements down keeping track of each bolts rod location in or out. So for example; say rod #1 inner bolt measures + .0005 and the outer is -.0006 vs the std. Lets say the spec is .0060-.0064. Now when you measure after stretching the inner should measure .0069-.0073 The outer should be .0054-.0058, This way you don't zero the gauge everytime. You can go back to your standard at anytime to check zero. Doug
[Re: mopar dave]
#3112101
01/15/23 12:02 PM
01/15/23 12:02 PM
Posts: 1,761 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Not sure I quite understand your standard zero method. I just zero gauge once before I start. Measure bolts loose, torque both bolts and remeasure for stretch. Go to next rod. I think the main idea is to have a repeatable 'reference point' (that being the fabricated standard) that you can always go back to. This takes out the +/- that might be introduced by the gauge/fixture as you are actively measuring the rod bolts. Basically, think of the inner workings of the gauge, or the potential movement of the components. So while resetting the gauge to 0 (zero) each time works for actual measurements, it does not provide you with the SAME starting point for EACH bolt...whereas the standard would, and it would remain that same for the remainder of time you needed to reference it (at least that's my interpretation of the procedure dvw uses.
[Re: Diplomat360]
#3112164
01/15/23 04:01 PM
01/15/23 04:01 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3112343
01/16/23 12:26 AM
01/16/23 12:26 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Thanks cab. It just bothers me the spec was 92lbft to arrive at the stretch spec and i got there with 75lbft. I might give Callie another call about this. Thanks again guys.
[Re: mopar dave]
#3112487
01/16/23 12:37 PM
01/16/23 12:37 PM
Posts: 3,087 Michigan
A727Tflite
I thought Molnar wanted his rod bolts torqued to yield? I have Molnar rods with his arp2000 bolts in my 511. I used his angle torqueing method, so i dont know the stretch on any of them. May want to check back with him. I don't think he would advocate "torque to yield". What is a torque-to-yield bolt? It is a one-time-use fastener that is designed to stretch during the torquing process (installation). Because of this stretching, the integrity of the bolt is compromised. These bolts cannot and should not be reused due to the stress caused to the bolt during its first installation.
