Re: Can you lengthen a driveshaft?
[Re: Sniper]
#3106133
12/28/22 02:59 PM
12/28/22 02:59 PM
Posts: 19,485 north of coder
moparx
Just note that those slip yoke that used the seal JK mentions have a vent hole on the end. another tidbit i had forgotten about. [oldtimer's disease strikes again. ] to the related topic at hand, did i miss just how much length needed to be added to the OP's driveshaft ? maybe there is a factory shaft for a different application that might work for his needed length ?
[Re: BDW]
#3106294
12/29/22 09:47 AM
12/29/22 09:47 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
My friend was a master machinist welder.He made many drive shafts for cars and semis.Never thought about trying to lenghten one.Made one for my Jeep from oil well pipe.He would cut off the ends in lathe then weld in new tube.Made one for semi wrecker I knew of for sure.Guy snapped like 3 factory ones.His ran for 5 years and was still good when he sold the truck
Chrysler Firepower
[Re: therocks]
#3106930
12/31/22 12:38 PM
12/31/22 12:38 PM
Posts: 4,740 Florida
BDW
Got my trans back, it will be awhile before I get it installed, but I think I'm ok. The 2 main things I have going for me is this 518 yoke is 1.0 - 1.5" longer than most 727 yokes, and there's 1.25" of splined shaft beyond the case end. The numbers in RED are if the yoke is pulled out an addition 0.5", looks like I still have 3.25" overlap on the splines. Check my math, hopefully I'm looking at this correctly
[Re: BDW]
#3107000
12/31/22 03:43 PM
12/31/22 03:43 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
Curious if lengthening a driveshaft is possible? After my Gen3 swap, engine moved forward, so the yoke engagement is less. Wasn't optimal before the swap, but now it's even less, probably ~1.5" back from bottoming out.
Wondered what detrimental affect the less yoke engagement might cause? When in doubt, replace it with a new beef up one with proper length one
[Re: BDW]
#3107008
12/31/22 03:59 PM
12/31/22 03:59 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Wondered what detrimental affect the less yoke engagement might cause? Possible? Yes Should you do it? No Agree with Cab and others. Either get a new stronger shaft made or replace the tube in yours. If you break a driveshaft it will cost you way more than a new shaft.
[Re: BSB67]
#3107060
12/31/22 07:39 PM
12/31/22 07:39 PM
BDW
Shaft is basically new, got it 8 yrs ago, less than 10k miles on it. It's a 3.25" DOM seamless with 7290 joints, cost me $400 back then
I don't mind spending money "if needed", but not looking to throw $500-$600 at something if not necessary. Was hoping someone had experience. If the trans shaft only has 3" of spline, is there benefit to have the yoke pushed in further. I know it can't hurt, but can't see how it would help.
[Re: BDW]
#3107268
01/01/23 04:20 PM
01/01/23 04:20 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Help me out, What and where is the bushing that will wear? The bushing is at the rear of the extension housing, just in front of the seal. The bushing surface can be bronze or babbitt.
[Re: BDW]
#3107833
01/02/23 10:16 PM
01/02/23 10:16 PM
Posts: 15,434 Omaha Ne
TJP
Omaha Ne
Update, got the trans installed and I should be ok. My measurement matches what the factory indicates, mine has a 1.5" pull back, in a perfect world I'd prefer only 1", but this will have to do. Yoke has over 5" inside the tail shaft, bushing looks to be only 3" or 4" long, so that's completely covered Just make sure that's not one of those Chinese tape measures 🙄, Also did you check the gravitational phase of the moon to earth before taking the measurement as it could be skewed. OK, Hip waders off, was getting a bit deep there LOL
[Re: TJP]
#3108468
01/04/23 03:14 PM
01/04/23 03:14 PM
moparx
Update, got the trans installed and I should be ok. My measurement matches what the factory indicates, mine has a 1.5" pull back, in a perfect world I'd prefer only 1", but this will have to do. Yoke has over 5" inside the tail shaft, bushing looks to be only 3" or 4" long, so that's completely covered Just make sure that's not one of those Chinese tape measures 🙄, Also did you check the gravitational phase of the moon to earth before taking the measurement as it could be skewed. OK, Hip waders off, was getting a bit deep there LOL is that measurement picture with, or without, cheater glasses being used for focus ?
