Re: 632 crate engine
[Re: Al_Alguire]
#3106140
12/28/22 03:32 PM
12/28/22 03:32 PM
Posts: 4,809 Wichita
GY3
Wichita
A Ramchargers 426 decal would fit nicely if you milled off the 632... This is what I've tried to do with our 505 RB. Hydraulic roller, big cubes, pump gas and lots of grunt. This just makes 400 more HP! It's so tempting to plug one in, add my plate kit to it and just never raise the hood!
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#3106169
12/28/22 05:34 PM
12/28/22 05:34 PM
Posts: 31,228 Oregon
AndyF
A Ramchargers 426 decal would fit nicely if you milled off the 632... This is what I've tried to do with our 505 RB. Hydraulic roller, big cubes, pump gas and lots of grunt. This just makes 400 more HP! It's so tempting to plug one in, add my plate kit to it and just never raise the hood! The extra 100 cubes adds some power but it doesn't add 400 hp. I think it is the heads that GM designed for these engines that really adds the power. They really flow well at all lifts to generate that much power at a low engine speed. Peak power is 6600 rpm with a redline of 7000. We're supposed to have the 632 on the dyno sometime in Jan so I'll know more then.
[Re: justinp61]
#3106386
12/29/22 02:19 PM
12/29/22 02:19 PM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
As a lifelong (I'm 61) Mopar fan it's disheartening to see all these gm crate engines and factory support available. And at pretty reasonable prices too. I can see why most young people stay away from Mopars. I agree....I would like to stay all Mopar, but engines like this at the price points they can be had, are really tough to ignore. I would not put one in my Cuda, but my bracket car, could be a different story.
[Re: Dragula]
#3106435
12/29/22 04:30 PM
12/29/22 04:30 PM
Posts: 16,938 NC
440Jim
NC
Isn't street price around $30,000 for the 632? With the EFI! Wow, what a deal. Throttle body, injectors, ignition system, electronic control unit, etc. The ZZ632 comes with the engine harness installed and the ECU calibrated/tuned to operate the engine across a wide range.
[Re: AndyF]
#3106438
12/29/22 05:03 PM
12/29/22 05:03 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I keep forgetting this is a Mopar website.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: pittsburghracer]
#3106457
12/29/22 06:12 PM
12/29/22 06:12 PM
GY3
Wichita
FCA (Mopar) forgot about us, so...
'63 Dodge 330
[Re: 440Jim]
#3106467
12/29/22 07:10 PM
12/29/22 07:10 PM
AndyF
Isn't street price around $30,000 for the 632? With the EFI! Wow, what a deal. Throttle body, injectors, ignition system, electronic control unit, etc. The ZZ632 comes with the engine harness installed and the ECU calibrated/tuned to operate the engine across a wide range. It is a good deal. I had about $10,000 in EFI costs on the 512 in my Duster. EFI is expensive when you do port injection plus coil near plug (no distributor). The costs really add up when you need cam and crank sensors as well as all of the extra harnesses and the higher end ECU. That engine with EFI cost me about $30,000 total. It was a low deck 512 with ported heads and a Wilson ported intake. It was a nice engine but it was 600/600 not 1000 hp.
[Re: justinp61]
#3106471
12/29/22 07:13 PM
12/29/22 07:13 PM
Posts: 4,457 Washington
madscientist
Washington
As a lifelong (I'm 61) Mopar fan it's disheartening to see all these gm crate engines and factory support available. And at pretty reasonable prices too. I can see why most young people stay away from Mopars. Yep. At 59 if I was going back to drag racing I’d do a BBC and not think twice about it.
[Re: dvw]
#3106487
12/29/22 08:49 PM
12/29/22 08:49 PM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
Hell, I don't have even close to $30K in the entire car. Doug How much can you build a 1000hp on pump 93 engine using new parts for?
[Re: dvw]
#3106602
12/30/22 10:49 AM
12/30/22 10:49 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I guess the question is why do you need pump gas with 1000hp? That much power on the street is usless. If you can afford $30k obviously race gas cost isn't an issue. New parts, budget parts, who cares if it works. Lastly I don't know about anybody else, but $30K isn't in most peoples realm of reality to purchase. Doug Thank you. I don’t even have near that in my B1 headed Keith Black 572 but then again I insist on doing most of my own work. I couldn’t afford to do what I do if I had to pay to do it.
#3106672
12/30/22 02:26 PM
12/30/22 02:26 PM
Posts: 8,090 Tulsa OK
Bad340fish
Tulsa OK
As crazy as the $30K number seems, it is a good value considering what it comes with it. Also from what I can tell they are not having any trouble selling them.
68 Barracuda Formula S 340
[Re: dvw]
#3106695
12/30/22 03:29 PM
12/30/22 03:29 PM
justinp61
W. Kentucky
I guess the question is why do you need pump gas with 1000hp? That much power on the street is usless. If you can afford $30k obviously race gas cost isn't an issue. New parts, budget parts, who cares if it works. Lastly I don't know about anybody else, but $30K isn't in most peoples realm of reality to purchase. Doug I build all of my stuff for pump gas, for several reasons, the biggest is mine get driven on the street and I can buy pump 93 at any local station, race gas, no. Apparently, there is a market for a 1000hp pump gas engines, and they will probably sell more of them than they would if they were 14-1 and made 1200hp on race gas or alcohol. Useless? By this reasoning why do we have Demons and Hellcats along with the high hp mustang and Camaro's? After all we only need enough power on the street to run the speed limit, right. Why do guys build 8 second drag cars? Because they want to, the same reasons some will have 1000hp on the street. It would be interesting to see what just the parts and machine work would cost to build that engine. I'm with John in the aspect of not doing this if I had to pay someone else to do most of the work. I'd venture that most on this forum are in the same boat.
[Re: justinp61]
#3106698
12/30/22 03:48 PM
12/30/22 03:48 PM
Posts: 9,998 MI, usa
dvw
MI, usa
Drive a red eye with the traction control turned off and the factory supplied tires. See how far that gets you. I have a 600hp street car with drag radials. Traction is optional. I've driven Dizusters 9.50 car on the street. You can A; spin the tires a long way. B: go fast enough once its rolling to get yourself in big trouble. So 1000hp on the street in a 3300lb car? Would be close to needing a 7.50 cage for strip duty. Not to mention a solid rod end 4 link. Cool yes. Usuable for much of anything? No. Doug
