Can someone identify what this cam grind is please? #3102989
12/16/22 09:58 PM
12/16/22 09:58 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
I bought this cam used, the lobes look good but it didn't come with a cam spec card. I've tried looking but I'm not finding any info that matches what I have. I'm probably looking in the wrong place, but anyway, I know someone on here will be able to spill out the specs for me,so if you can, thank you very much.
Re: Can someone identify what this cam grind is please? [Re: rebel] #3103004
12/16/22 11:02 PM
12/16/22 11:02 PM
CC equals Comp Cams, look up the lobes or degree it at .050 lobe lift to see what grind it is work scope wrench
Re: Can someone identify what this cam grind is please? [Re: rebel] #3103007
12/16/22 11:22 PM
12/16/22 11:22 PM
CA
crackedback Offline
crackedback  Offline
CA
1737 lobe
320/287 .515 lobe lift
1871
330/292 .500 lobe lift
Re: Can someone identify what this cam grind is please? [Re: crackedback] #3103008
12/17/22 12:06 AM
12/17/22 12:06 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Originally Posted by crackedback
1737 lobe
1871
Thanx
Re: Can someone identify what this cam grind is please? [Re: rebel] #3103045
12/17/22 10:02 AM
12/17/22 10:02 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
112 lobe sep
