Re: Randy Williams NPK Challenger
[Re: GY3]
#3101277 12/11/2212:35 PM12/11/2212:35 PM
I've noticed how most all the NPK guys run with an exposed trans. I understand between-rounds maintenance/repairs, but that seems iffy. Hot ATF, shrapnel, or whatever - regardless of the specific trans case, it just seems odd to me.
[Re: topside]
#3101293 12/11/2201:28 PM12/11/2201:28 PM
i never felt comfortable with that as well.
[Re: moparx]
#3101317 12/11/2202:23 PM12/11/2202:23 PM
Not that I have any reason to talk, but his old Dart and Dominator's Dart look like monster trucks going down the track compared to how down low everyone else is and man that Chally is slick!
I'm way behind on the current NPK season but there has been ALOT of fluid in the cabin this season...
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: LA360]
#3101450 12/11/2210:02 PM12/11/2210:02 PM
That’s why they stipulate a minimum of SFI 15 clothing for an open trans.
[Re: mopar_mark]
#3101583 12/12/2201:36 PM12/12/2201:36 PM
Wizzard Racecars builds some really cool stuff. The did the chassis on my new truck. I have seen alot of thier work and always impressed. This is clearly no exception.
[Re: topside]
#3101584 12/12/2201:40 PM12/12/2201:40 PM
Do you think a thin piece of carbon or aluminum help much? If pieces can get out of the case they canb easily go through the thin cover material.. The part I dont like is the proximity of the driveshaft which is why they require tunnels as well for that. But it took a badly mangled arm to bring that about.
[Re: Al_Alguire]
#3101639 12/12/2204:23 PM12/12/2204:23 PM
No, I don't think carbon fiber or thin aluminum sheet would offer any real protection against anything but fluid... That would take at least a ballistic blanket or something equivalent, but no matter, it's apparently OK. Agreed on the yoke area; I would think more could be done there on some of the cars.
[Re: topside]
#3101665 12/12/2205:56 PM12/12/2205:56 PM
I think Ryan Martin had a failure in the yoke joint area in a NPK episode. Could have been last season. Some of the shrapnel exited the roof. That area is just scary. You would think that area would have some type of protection, especially an exposed yoke assemble.
[Re: RROD]
#3103839 12/20/2209:21 AM12/20/2209:21 AM
