Re: MAGNUM 5.2 THERMOSTAT/HOUSING [Re: 2boltmain] #3103829
12/20/22 08:42 AM
12/20/22 08:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
One picture shows the machined underside.
The flange looks oversized, and “maybe” overhangs the mating flange edges on the intake manifold ?
Re: MAGNUM 5.2 THERMOSTAT/HOUSING [Re: 360view] #3103855
12/20/22 10:03 AM
12/20/22 10:03 AM
Andrewh Offline
Andrewh  Offline
I haven't tried to put it on yet. will be a while before I get there.
I can measure if you have the stamped one handy or the bare intake to check.
Re: MAGNUM 5.2 THERMOSTAT/HOUSING [Re: Andrewh] #3104005
12/20/22 04:23 PM
12/20/22 04:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’ll try to make this one work, a little machining on the face. Have no idea what it came off of.
Re: MAGNUM 5.2 THERMOSTAT/HOUSING [Re: cudaman1969] #3104178
12/21/22 07:51 AM
12/21/22 07:51 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
The stock ones are angled a bit towards the motor for clearance, That looks straight so you will have issues if you have the ac compressor and accessory bracket.
Re: MAGNUM 5.2 THERMOSTAT/HOUSING [Re: Andrewh] #3104371
12/21/22 10:27 PM
12/21/22 10:27 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Was gonna order the aluminum unit in my link but they're gone- at least from that seller.
Keep old mopars alive.
