Re: Stock stroke 440/Aluminum heads cam choice [Re: Pool Fixer] #3100053
12/06/22 10:17 AM
12/06/22 10:17 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The cnc porting is just icing on the cake. It makes the Stealths come alive! No effect on streetability.
As far as fuel injection, we have run a Demon 850 carb on the street for over 7 years now and it starts instantly and runs great! Very little finessing to get it right.
We did a Howards hydraulic roller and it's a great cam. No noisy valvetrain, sounds like a mild cam in a stock engine. Maintenance free as you can set the pre-load and never mess with it again.
I'm a fan of good headers as we run Hedman 78030's. No denting necessary and they are 1 3/4. More than enough flow as we have run in the low 10's at 133 mph with them. Lots of plug/wire clearance and easy install.
'63 Dodge 330
11.19 @ 121 mph
Re: Stock stroke 440/Aluminum heads cam choice [Re: Pool Fixer] #3103389
12/18/22 06:09 PM
12/18/22 06:09 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Originally Posted by Pool Fixer
What's wrong with towing it facing backwards?
