Re: street/strip 511" build with dyno results
[Re: Brad_Haak]
#3099155
12/03/22 10:37 AM
12/03/22 10:37 AM
Posts: 898 Missouri
jwb123
Missouri
It has a battery hold down, two throttle springs and I tossed the Yosemite Sam floor mats when we got the car.
Are they supposed to be checking for something else?
Safety belts Scatter shield (4-speed) Roll bar or cage (bar >= 10.00; cage <10.00) Driveshaft loop Driver's jacket ... and the list gets longer as the car gets faster Or are you running at an "outlaw" track that doesn't really bother w/ tech inspection per the NHRA/IHRA rules? Nice build but I have been racing a long time seen lots of stuff. Just because you race on the street or an outlaw track, don't skip the safety stuff. One thing about trying to put that much HP on the street is you are usually very close to spinning the tires at a lot of MPH. Bad things can happen. And TV show or not those street racers have had a lot of wrecks the past few years both on and off the track, couple got killed. So be safe. And if done correctly a good roll cage will stiffen the car and make it go faster, done that myself several times.
[Re: Jeremiah]
#3099209
12/03/22 02:11 PM
12/03/22 02:11 PM
Posts: 8,225 Plymouth, MI
Blusmbl
Plymouth, MI
I've heard RPM and heavy bobweight kills the LY rods. I don't think I'm making enough power to hurt them but I also don't think they are safe long term much above 6000 rpm. What are the performance targets for the car?
On spray and N/A? N/A - snappin necks On spray - cashin checks! That is such a grudge racer answer.
[Re: CSK]
#3099275
12/03/22 05:59 PM
12/03/22 05:59 PM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
Impressive numbers, must be one of the reasons why Charlie’s Car runs so good. I should probably crawl out from under my rock more often.
Rich H.
Esse Quam Videri
[Re: jwb123]
#3099281
12/03/22 06:09 PM
12/03/22 06:09 PM
Posts: 9,113 Rogue River, OR
Jeremiah
Rogue River, OR
Safety belts Scatter shield (4-speed) Roll bar or cage (bar >= 10.00; cage <10.00) Driveshaft loop Driver's jacket ... and the list gets longer as the car gets faster Or are you running at an "outlaw" track that doesn't really bother w/ tech inspection per the NHRA/IHRA rules? Nice build but I have been racing a long time seen lots of stuff. Just because you race on the street or an outlaw track, don't skip the safety stuff. One thing about trying to put that much HP on the street is you are usually very close to spinning the tires at a lot of MPH. Bad things can happen. And TV show or not those street racers have had a lot of wrecks the past few years both on and off the track, couple got killed. So be safe. And if done correctly a good roll cage will stiffen the car and make it go faster, done that myself several times. Gentlemen....11.50 tops! Looking for 88mph in the 1/8th
[Re: Blusmbl]
#3099282
12/03/22 06:13 PM
12/03/22 06:13 PM
Jeremiah
Rogue River, OR
On spray and N/A? N/A - snappin necks On spray - cashin checks! That is such a grudge racer answer. Oh man...I dont even have any tattoos. One of my biggest pet peeves is the outlaw gangster racer thing. More like working 80 hours a week supporting a family and your car hobby. Flat bill hat and a hoodie doesn"t mean ****
[Re: jwb123]
#3099285
12/03/22 06:22 PM
12/03/22 06:22 PM
Jeremiah
Rogue River, OR
Safety belts Scatter shield (4-speed) Roll bar or cage (bar >= 10.00; cage <10.00) Driveshaft loop Driver's jacket ... and the list gets longer as the car gets faster Or are you running at an "outlaw" track that doesn't really bother w/ tech inspection per the NHRA/IHRA rules? Nice build but I have been racing a long time seen lots of stuff. Just because you race on the street or an outlaw track, don't skip the safety stuff. One thing about trying to put that much HP on the street is you are usually very close to spinning the tires at a lot of MPH. Bad things can happen. And TV show or not those street racers have had a lot of wrecks the past few years both on and off the track, couple got killed. So be safe. And if done correctly a good roll cage will stiffen the car and make it go faster, done that myself several times. You make several good points here. I will take them into consideration as we move forward (that is my serious answer).
[Re: HardcoreB]
#3101011
12/10/22 01:12 AM
12/10/22 01:12 AM
Jeremiah
Rogue River, OR
Thank you for the feedback. I intend to measure the volume of each intake.
I probably won't though : D
Would measuring height and runner CSA be valuable data?
Is this bad time to talk about a hood swap?
[Re: Jeremiah]
#3101013
12/10/22 01:15 AM
12/10/22 01:15 AM
Jeremiah
Rogue River, OR
Also stumbled upon some TTI step headers. Sorry red Charger! I already feel guilty lol.
[Re: moparx]
#3102157
12/14/22 07:44 AM
12/14/22 07:44 AM
Jeremiah
Rogue River, OR
Easier to weld up the exhaust that way. I wish they would fix that issue...which is about 5 years old lol.
