Re: street/strip 511" build with dyno results
[Re: powertrip]
#3098384
11/30/22 01:46 PM
11/30/22 01:46 PM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
Finding a low deck single plane took a while! Glass 6 pack hood on the way!
[Re: Jeremiah]
#3098400
11/30/22 03:03 PM
11/30/22 03:03 PM
Posts: 9,883 MI, usa
dvw
MI, usa
As it sits we will make 800+ on nitrous.
The heck with more motor work. I'd be saving up for a trans Doug
[Re: dvw]
#3098471
11/30/22 06:35 PM
11/30/22 06:35 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
The heck with more motor work. I'd be saving up for a trans Doug Me thinks he has several different choices to use in his shop, HUH Jeremiah: whistling: ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: FastmOp]
#3098543
11/30/22 10:36 PM
11/30/22 10:36 PM
Jeremiah
Rogue River, OR
The heck with more motor work. I'd be saving up for a trans Doug You make an excellent point there. The transmission and clutch are maxed out with this engine on a power adder. A g force 101a will replace the a833 at some point. My original plan was a smaller porter racing heads street roller cam and stealth head upgrade to the 451. That block is headed to get a sleeve and some good rods this winter. It will be interesting to see how much n/a power can be made with the stock manifolds.
[Re: rebel]
#3098572
12/01/22 03:00 AM
12/01/22 03:00 AM
Jeremiah
Rogue River, OR
645 wheel hp is no joke. I would be very happy with 650whp on the wheel dyno on a small n20 kit. My previous best with the 451" was 572whp on a 175 shot. Thinking I can run either a lean 125hp tune up or 150hp jets pulling some timing to reach my goal.
Naturally all of that hp gets skewed off the chart when the clutch tamer, n20 progressive and erratic track conditions come into play. Add in the flashlight start and it's anyone's guess if we are leaving off of the progressive's time delay or not lol.
[Re: Jeremiah]
#3098596
12/01/22 09:57 AM
12/01/22 09:57 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Junk. It didn't meet your torque goal. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Just kidding!!! That's a really cool combo and I'm surprised at the power w/ unported Stealth heads! That car should really make some people scratch their heads after it makes a pass! I love these type of bada$$, but unsuspecting builds. To those questioning the size of the cam...remember, it's a nitrous motor. That changes things. I've seen some crazy big cam specs for motors that if weren't being sprayed hard, you'd think were WAYY overcammed.
[Re: an8sec70cuda]
#3098824
12/02/22 01:12 AM
12/02/22 01:12 AM
Jeremiah
Rogue River, OR
All of my custom n20 cams have longer exhaust duration.
This thing also needs moderate RPM to do it's thing. I can't leave off idle or anywhere down low like an automatic; I need RPM to slip the clutch and keep the nitrous kit from sending the carbutetor to heaven. With a 4.10 gear and a 28" tire my usable down track rpm operating window is 4400-6150. At 4400 RPM we are making within 20 ft-lb of peak tq and 500hp and by 5100 RPM we have picked up 100 hp and it carries until redline. Lastly, the engine makes just short of 600 ft lbs at 3900 so I am not really sure why we are calling it a narrow power band. Maybe someone has a dyno sheet from a similar build as an example? I have had a few people indicate the engine is down on power yet no one will tell me why lol.
[Re: Cab_Burge]
#3098826
12/02/22 01:28 AM
12/02/22 01:28 AM
Jeremiah
Rogue River, OR
The heck with more motor work. I'd be saving up for a trans Doug Me thinks he has several different choices to use in his shop, HUH Jeremiah: whistling: Maybe a couple : D That said the face plated a833 has served me well. I ordered a spare set of gears and a cluster and have not had cause to use them. Slipping the clutch is the only thing keeping it alive. I also adjust the RPM window switch to turn off the nitrous below 4500 and above 6100 which really helps on the 2-3 and 3-4 shift. If any of you automatic guys want to know what it feels like to shift out of 3rd gear let me know : D. Just having fun no disrespect intended.
[Re: Blusmbl]
#3098829
12/02/22 01:42 AM
12/02/22 01:42 AM
Jeremiah
Rogue River, OR
That's super inconspicuous, I dig it! Really impressive power from unported Stealths! Thank you Nick it has been a humorous and entertaining journey. There are so many facets to gettijg a csr like this to work half way right sometimes I am like a blind man trying to open a can of beans with a swiss army knife. I am looking forward to seeing where your fury upgrade goes. These street cars can be pretty darn fun with a little nitrous don't you think?
[Re: powertrip]
#3098830
12/02/22 01:51 AM
12/02/22 01:51 AM
Jeremiah
Rogue River, OR
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program?
[Re: Jeremiah]
#3098858
12/02/22 07:53 AM
12/02/22 07:53 AM
dvw
MI, usa
[Re: Jeremiah]
#3098870
12/02/22 09:30 AM
12/02/22 09:30 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
This thing also needs moderate RPM to do it's thing. I can't leave off idle or anywhere down low like an automatic; I need RPM to slip the clutch and keep the nitrous kit from sending the carbutetor to heaven. With a 4.10 gear and a 28" tire my usable down track rpm operating window is 4400-6150. At 4400 RPM we are making within 20 ft-lb of peak tq and 500hp and by 5100 RPM we have picked up 100 hp and it carries until redline. Lastly, the engine makes just short of 600 ft lbs at 3900 so I am not really sure why we are calling it a narrow power band. Maybe someone has a dyno sheet from a similar build as an example? I have had a few people indicate the engine is down on power yet no one will tell me why lol. Down on power ??? I think not, for the cyl head you are makin some STEAM, cant wait for the track results !!!!!
[Re: Jeremiah]
#3098874
12/02/22 09:41 AM
12/02/22 09:41 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program? Unless you wanted to run totally N/A I don't feel like there's bang for the buck having them cnc'd. I'd think there is that same '40HP' or so just doing a few hours of MW opening to the intake runners and then using a MW intake which would carry power further. It's a strong build for unported stealth heads! Them being small and that you were using low compression for pump, AND in consideration of the valvetrain; I may have missed on the cam by 5HP and for that I'm so sorry ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) . I'd have thought it would have power peaked about 200 higher but not exactly sure where the ICL is at currently. I'd bet moving it would shift peak for sure. I don't recall if you mentioned how much spark adv made the best power? For whatever reason, your builds go relatively unnoticed (and maybe that is your goal) but they are impressive relative to the parts you're using. Again overall GOOD JOB!
[Re: HardcoreB]
#3098878
12/02/22 09:51 AM
12/02/22 09:51 AM
Posts: 1,185 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I haven't read everybody's responses, so this may have been mentioned already...
It's only a "narrow" power curve if all you do is compare the HP peak RPM with the torque peak RPM. If you look at where the torque is > 550 lb-ft, the answer is "almost everywhere".
I think the HP NA is maxed w/ the unported heads; if you port the heads, the next restriction is that intake. If you always spray it to your horsepower goal, I don't see the point in changing what you have now.
Does that car have to pass tech to race where you do? I don't see much there that says you do...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Jeremiah]
#3098901
12/02/22 11:36 AM
12/02/22 11:36 AM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
I am looking forward to seeing where your fury upgrade goes. These street cars can be pretty darn fun with a little nitrous don't you think? That's a fantastic quote!!! It's super cool, there isn't anything more exciting than a quick manual trans Mopar. It should really, really fly on the hose! My car is overcammed for n/a work, but it worked great on the nitrous. It picked up 1.2-ish seconds on only a 73 jet, the added duration really helps. It's addicting for sure, doing caltracs/monos/vikings on all 4 corners this winter, and am going to possibly upgrade the fuel system so I can feel safe spraying 225+... at least from a tune standpoint, not from a stock LY rods and six pack pistons standpoint, lol
