Re: street/strip 511" build with dyno results
[Re: Jeremiah]
#3098902
12/02/22 11:37 AM
12/02/22 11:37 AM
Posts: 3,113 Michigan
A727Tflite
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program? Last numbers I was given from a set were 346 at 7, 348 at 8. Exhaust were 229 at 7, 232 at 8. 2.14/1.81. 4.38 bore
[Re: dvw]
#3098909
12/02/22 11:57 AM
12/02/22 11:57 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
I ran out of tape for the seats but the lap belt clicks in really good (Doug makes good points as always).
[Re: HardcoreB]
#3098911
12/02/22 12:01 PM
12/02/22 12:01 PM
Jeremiah
Rogue River, OR
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program? Unless you wanted to run totally N/A I don't feel like there's bang for the buck having them cnc'd. I'd think there is that same '40HP' or so just doing a few hours of MW opening to the intake runners and then using a MW intake which would carry power further. It's a strong build for unported stealth heads! Them being small and that you were using low compression for pump, AND in consideration of the valvetrain; I may have missed on the cam by 5HP and for that I'm so sorry ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) . I'd have thought it would have power peaked about 200 higher but not exactly sure where the ICL is at currently. I'd bet moving it would shift peak for sure. I don't recall if you mentioned how much spark adv made the best power? For whatever reason, your builds go relatively unnoticed (and maybe that is your goal) but they are impressive relative to the parts you're using. Again overall GOOD JOB! Thank you for the support. I figured on struggling to find 600hp with the unported heads. I have one more set of Stealths to mess with so we will have to make plan for those. What didn't we like on the valvetrain? I sure wish the crane steel rockers came with more ratio options.
[Re: Brad_Haak]
#3098913
12/02/22 12:04 PM
12/02/22 12:04 PM
Jeremiah
Rogue River, OR
I haven't read everybody's responses, so this may have been mentioned already...
It's only a "narrow" power curve if all you do is compare the HP peak RPM with the torque peak RPM. If you look at where the torque is > 550 lb-ft, the answer is "almost everywhere".
I think the HP NA is maxed w/ the unported heads; if you port the heads, the next restriction is that intake. If you always spray it to your horsepower goal, I don't see the point in changing what you have now.
Does that car have to pass tech to race where you do? I don't see much there that says you do... It has a battery hold down, two throttle springs and I tossed the Yosemite Sam floor mats when we got the car. Are they supposed to be checking for something else? Thanks for sharing your thoughts on the hp/tq. Good food for thought!
[Re: A727Tflite]
#3098914
12/02/22 12:06 PM
12/02/22 12:06 PM
Jeremiah
Rogue River, OR
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program? Last numbers I was given from a set were 346 at 7, 348 at 8. Exhaust were 229 at 7, 232 at 8. 2.14/1.81. 4.38 bore Whoa! I had no idea. My understanding was 320@.700. Thank you for sharing that info.
[Re: Blusmbl]
#3098917
12/02/22 12:10 PM
12/02/22 12:10 PM
Jeremiah
Rogue River, OR
Thank you Nick it has been a humorous and entertaining journey. There are so many facets to gettijg a csr like this to work half way right sometimes I am like a blind man trying to open a can of beans with a swiss army knife.
I am looking forward to seeing where your fury upgrade goes. These street cars can be pretty darn fun with a little nitrous don't you think? That's a fantastic quote!!! It's super cool, there isn't anything more exciting than a quick manual trans Mopar. It should really, really fly on the hose! My car is overcammed for n/a work, but it worked great on the nitrous. It picked up 1.2-ish seconds on only a 73 jet, the added duration really helps. It's addicting for sure, doing caltracs/monos/vikings on all 4 corners this winter, and am going to possibly upgrade the fuel system so I can feel safe spraying 225+... at least from a tune standpoint, not from a stock LY rods and six pack pistons standpoint, lol The LY rods in my GTS looked mint other than #4 which bent due to the cylinder splitting and filling with a coolant. Bearings looked perfect on all mains and rod bearings. I was really surprised by that. Looking forward to seeing how much you pick up with a suspension upgrade on the Fury!
[Re: Jeremiah]
#3098920
12/02/22 12:14 PM
12/02/22 12:14 PM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Safety belts Scatter shield (4-speed) Roll bar or cage (bar >= 10.00; cage <10.00) Driveshaft loop Driver's jacket ... and the list gets longer as the car gets faster Or are you running at an "outlaw" track that doesn't really bother w/ tech inspection per the NHRA/IHRA rules?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Jeremiah]
#3098922
12/02/22 12:17 PM
12/02/22 12:17 PM
Brad_Haak
Loudoun County, VA
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program? Last numbers I was given from a set were 346 at 7, 348 at 8. Exhaust were 229 at 7, 232 at 8. 2.14/1.81. 4.38 bore Whoa! I had no idea. My understanding was 320@.700. Thank you for sharing that info. They only claimed around 320-ish, so I have no idea where 340++ #s would come from... The last CNC Stealths I saw tested (Dwayne posted something about them in the last year or so) didn't even get to 320; MCH isn't doing the work any longer, so the additional blending & CNC chamber work that goes along with the basic CNC work to the ports alone isn't being done any more, IIRC.
[Re: Brad_Haak]
#3098923
12/02/22 12:21 PM
12/02/22 12:21 PM
Jeremiah
Rogue River, OR
Safety bellhousing, billet flywheel....check Driveshaft loop....check
I will have to double check on the rest of that list lol
[Re: Jeremiah]
#3098924
12/02/22 12:32 PM
12/02/22 12:32 PM
Posts: 4,105 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program? Last numbers I was given from a set were 346 at 7, 348 at 8. Exhaust were 229 at 7, 232 at 8. 2.14/1.81. 4.38 bore Whoa! I had no idea. My understanding was 320@.700. Thank you for sharing that info. Yeah i dont think you'll see 340+ cfm out of a 2.14 Stealth that is remotely affordable. Call the numbers however you want but ported you'd do REALLY well to get over 700 on a decent motor build similar to this.
[Re: Jeremiah]
#3098925
12/02/22 12:35 PM
12/02/22 12:35 PM
HardcoreB
Shelby Twp. Mi
I would not be surprised if you find another 40 hp with a bigger manifold and well-ported heads. Do you know what the flow nu,bers for a CNC ported stealth look like? Who has the best program? Unless you wanted to run totally N/A I don't feel like there's bang for the buck having them cnc'd. I'd think there is that same '40HP' or so just doing a few hours of MW opening to the intake runners and then using a MW intake which would carry power further. It's a strong build for unported stealth heads! Them being small and that you were using low compression for pump, AND in consideration of the valvetrain; I may have missed on the cam by 5HP and for that I'm so sorry ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) . I'd have thought it would have power peaked about 200 higher but not exactly sure where the ICL is at currently. I'd bet moving it would shift peak for sure. I don't recall if you mentioned how much spark adv made the best power? For whatever reason, your builds go relatively unnoticed (and maybe that is your goal) but they are impressive relative to the parts you're using. Again overall GOOD JOB! Thank you for the support. I figured on struggling to find 600hp with the unported heads. I have one more set of Stealths to mess with so we will have to make plan for those. What didn't we like on the valvetrain? I sure wish the crane steel rockers came with more ratio options. The valvetrain is good and matched for what your doing but there is better like HS and TD paired etc. but again that all goes into consideration in the whole scheme.
[Re: HardcoreB]
#3098936
12/02/22 01:21 PM
12/02/22 01:21 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What are the performance targets for the car?
On spray and N/A?
[Re: fast68plymouth]
#3098963
12/02/22 03:30 PM
12/02/22 03:30 PM
Jeremiah
Rogue River, OR
On spray and N/A? N/A - snappin necks On spray - cashin checks!
[Re: Jeremiah]
#3099006
12/02/22 05:17 PM
12/02/22 05:17 PM
Posts: 17,923 S.E. Michigan
ZIPPY
S.E. Michigan
340+ cfm stealth heads?
Just when I thought I'd seen everything
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3099126
12/03/22 01:18 AM
12/03/22 01:18 AM
Jeremiah
Rogue River, OR
Just when I thought I'd seen everything Has anyone ever seen a set of functioning "super stealths" ? I recollect them having flow numbers reported in the 340 range. The intake port wall looked very thin on one side from the pics in 440sources ad.
[Re: Jeremiah]
#3099129
12/03/22 02:21 AM
12/03/22 02:21 AM
Posts: 2,883 Pattison Texas
CSK
Pattison Texas
Just when I thought I'd seen everything Has anyone ever seen a set of functioning "super stealths" ? I recollect them having flow numbers reported in the 340 range. The intake port wall looked very thin on one side from the pics in 440sources ad. They have 440 size ports, but the pinch is moved over so .650 offset intake rockers must be used, I ported mine & are Max wedge size, Mine flow in the 340's , had them on my junk for many years
[Re: CSK]
#3099142
12/03/22 07:57 AM
12/03/22 07:57 AM
Jeremiah
Rogue River, OR
Very cool! I want a set! I dont think they still sell the super version?
[Re: Jeremiah]
#3099148
12/03/22 09:30 AM
12/03/22 09:30 AM
A727Tflite
Just when I thought I'd seen everything Has anyone ever seen a set of functioning "super stealths" ? I recollect them having flow numbers reported in the 340 range. The intake port wall looked very thin on one side from the pics in 440sources ad. These were done by MCH - All I know is what I saw on the flow test sheet. Don’t know if they require special rockers or not.
