Page 2 of 3 1 2 3
Re: Drag Radial launch question with Vids [Re: TheOtherDodge] #3098184
11/29/22 07:26 PM
11/29/22 07:26 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
An easy fix...?
Re: Drag Radial launch question with Vids [Re: Dart 500] #3098292
11/30/22 09:25 AM
11/30/22 09:25 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice videos. It's really spinning which makes me wonder how much you'd gain making it work. What are the incrementals?
Re: Drag Radial launch question with Vids [Re: HardcoreB] #3098296
11/30/22 09:34 AM
11/30/22 09:34 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Awesome truck, by the way! I should've mentioned that first. Totally agree about the radials, it makes them so much more confidence inspiring to drive. Only drawback is they don't work as well for no prep type stuff but it seems people are getting them to work on those surfaces now too. The guy who won the small tire class at Roadkill nights this year was on a radial!
Re: Drag Radial launch question with Vids [Re: HardcoreB] #3098325
11/30/22 11:03 AM
11/30/22 11:03 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
A couple of weeks ago in ok air (78 degrees, 55% humidity) on 14.5 lbs of boost it went: 1.44, 6.29@109.96, 9.91@134.43. It hooked but I was leaving on only 3,200 rpms (4.5 lbs of boost). On the big end I was experiencing a "slight stammer" which turned out to be spark blow out. I resolved that but these latest passes were only on an 1/8 mile track and I was ok with that since I wanted to work on my 60fts anyway.
The biggest limitations are the small cam (.220/.520) and "cheap" turbo. But then if I upgrade those 2 things, my stock block becomes the limitation! "One Day", I will move to the Gen III Hemi platform.
Re: Drag Radial launch question with Vids [Re: Blusmbl] #3098327
11/30/22 11:04 AM
11/30/22 11:04 AM
Houston, Texas
Houston, Texas
Once you go Radials, you never go back!
Re: Drag Radial launch question with Vids [Re: TheOtherDodge] #3098328
11/30/22 11:12 AM
11/30/22 11:12 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I'm interested in seeing how the ET Street R compares to the original ET Street Radial on my '73. From what I've read, the current S/S is basically the original version w/ additional grooves for water channeling. The "R" is supposed to be the street-legal version of the "Pro" with a different sidewall construction. I still have a couple of new sets of the original 275/60s to burn through first.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Drag Radial launch question with Vids [Re: Brad_Haak] #3098332
11/30/22 11:23 AM
11/30/22 11:23 AM
Houston, Texas
Houston, Texas
Brad, my understanding is that the Pro have the "best" compound. And since the person who does most of the tuning (Eric Stubbs) runs 4.0's on 275 R's, I just copied him! Once I blow through this set which don't have a lot of passes, he wants me to go to a smaller tire.
This was Eric the same day I went:
https://www.facebook.com/100000100240304/videos/875890863412940/
Re: Drag Radial launch question with Vids [Re: TheOtherDodge] #3098336
11/30/22 11:37 AM
11/30/22 11:37 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That's my understanding too. The SS and R both have the same compound, but the R has a softer sidewall. The Pro is better than both, and is technically street legal, but has no rain grooves at all.
Re: Drag Radial launch question with Vids [Re: Blusmbl] #3098337
11/30/22 11:42 AM
11/30/22 11:42 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I had to go dig this up, since I couldn't remember where the differences between the various ET Street versions are: https://www.streetmusclemag.com/news/inside-mts-new-drag-radial-lineup-pro-bracket-et-street-ss-r/
Re: Drag Radial launch question with Vids [Re: Blusmbl] #3098340
11/30/22 11:59 AM
11/30/22 11:59 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Oh, c'mon, it has TWO, TWO "rain grooves". grin
Perfectly fine for street driving.
'63 Dodge 330
11.19 @ 121 mph
Re: Drag Radial launch question with Vids [Re: Tig] #3098350
11/30/22 12:10 PM
11/30/22 12:10 PM
UK
rb446 Offline
rb446  Offline
UK
Tig : You need more help than I do, but for a different issue!
Very True, we are into 5 figures now repairing stuff from several big wheelstands blush, the car isn't even that quick grin I don't know if its a Caltrac thing, but we have tried tightening the front up and / or limiting front rise to stop the wheelstand. Always ends up knocking the tyres off or rattling them some.
We can spend most of a qualifying day chasing our tail if we get it wrong. We cant take any more rise (anti squat) out of the car mechanically, it just seems to need to have a loose front and anti squat in the rear to run it's best. shruggy We're going to have to get a handle on it quick with potentially an extra 700 hp whistling (bigger engine + 500 hp N2O dual fogger). IF we ever bust out of the 8.50 cage cert, we will make the rear more adjustable for ride height next time round but keep the caltracs and small tyres. up
From what I've been reading you need more anti squat not take it out, the more rise you have the more it will tend to push the car forward and keep the front down. fwiw... Same for Duncans 622 Hemi@1000hp+, he tightened the fronts to max and it wasn't enough so he's just staying out of the throttle some to get it to go down from what I see. Try looking at Kevin Wilson on u-tube, the chassis man, could help you some if you sift out the elementary stuff.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Drag Radial launch question with Vids [Re: rb446] #3098406
11/30/22 03:23 PM
11/30/22 03:23 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Agree - to a point - there is too much anti squat un-intentionally designed into the car and not enough weight over the front, it's just the way it's ended up. Even on the least aggressive rear settings mechanically, it will kill the sidewalls in a bias ply slick, way before the tread is worn out.
It appears current thinking is more weight over the front and plenty of rise for radials, the no prep radial set up you tube vids are quite interesting. I've posted some you tube stuff by Kevin some while ago on my facebook page, I even think you may have commented on it grin
Re: Drag Radial launch question with Vids [Re: Tig] #3098412
11/30/22 03:49 PM
11/30/22 03:49 PM
UK
rb446 Offline
rb446  Offline
UK
Yeah was watching one myself where the back of one of those cars rises up some way down track presumably when the power really comes on to stop it going airborn. Hope I'm there to see you runnning1500hp in that car. I know the l/spring Digby Dart has gone 4.24@181 on springs but thats a whole different ball game.
Re: Drag Radial launch question with Vids [Re: GY3] #3098436
11/30/22 04:51 PM
11/30/22 04:51 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Totally legit, lol
Re: Drag Radial launch question with Vids [Re: Blusmbl] #3098462
11/30/22 06:02 PM
11/30/22 06:02 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
So at drag week this year I wandered over to the Mickey Thompson tent when I was wandering around waiting for things to happen. I asked them why the 275 Pro was directional, he then proceeded to tell me that it is because the rain grooves are only designed to push water out one direction lol. So I assume they Probably up the safe rain driving speed from 9 mph to 11 over a standard slick.
I really like the radials though, they wear good, they hold the same air pressure for MONTHS and the car drives soooo nice.
68 Barracuda Formula S 340
Re: Drag Radial launch question with Vids [Re: Bad340fish] #3098492
11/30/22 07:37 PM
11/30/22 07:37 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
grin
I drove my Dart to work one day and it rained, when I left it wasn't raining but the roads were still wet. I run the ET Street R's with the two full groves around them, needless to say it was a white knuckle 35mph ride home. I never drove it again if there was a chance of rain. LOL
Re: Drag Radial launch question with Vids [Re: justinp61] #3098584
12/01/22 07:45 AM
12/01/22 07:45 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Gotta drive it like a sprint car!
Re: Drag Radial launch question with Vids [Re: fbs63] #3098591
12/01/22 08:49 AM
12/01/22 08:49 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
One of these is not like the others... it's the one that's not legal for street use
Re: Drag Radial launch question with Vids [Re: Brad_Haak] #3098598
12/01/22 10:00 AM
12/01/22 10:00 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The 275 Pro Carries a DOT Number. It is the most illegal looking one of that bunch.
I actually like the 275 Pro a little better than the pro bracket radial. They hold the rim better for some reason and I believe the sidewall is a little stiffer and my car seems to like that.
Re: Drag Radial launch question with Vids [Re: Brad_Haak] #3098603
12/01/22 10:05 AM
12/01/22 10:05 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I was gonna say the ET Street PRO isn't legal. It has the DOT stamp on it, but says on the sidewall not for highway use.
Brad...the ET Street R seems to be better than the old style ET Street. I got the new tire 2 years ago and have been really happy w/ them.
I use the 295-65. The 275-60 looks stupid on my car. I'm used to the look of the bigger tire and the stance of the car doesn't suit the short tire very well. The 315-60 doesn't fit on mine.
CHIP
'06 GMC 2500HD LBZ Duramax
Page 2 of 3 1 2 3
