Page 1 of 4 1 2 3 4
street/strip 511" build with dyno results #3098206
11/29/22 08:56 PM
11/29/22 08:56 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Howdy,
I was asked to share my 511 low deck build that will live in our "68 Dart GTS. The engine was built within the following parameters:
-Must fit under stock hood with n20 plate and 4" filter
-Can run on pump 91 in a pinch (I am a Sunoco 110 guy)
-Stock appearing long block i.e. aside from headers, intake and carb it resembles an original 383 magnum
-250hp nitrous friendly
-target hp/tq 625/625, 6500 max engine speed (shift 6200ish, cross stripe 6100ish)
The car is 3550 lb on the starting line with driver etc. I am moving up to a 28x11.50 ET Bias DOT and also have a set of 28x9st (stiff wall) to try.
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098209
11/29/22 09:01 PM
11/29/22 09:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Howdy , I see no dyno sheet smile
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098210
11/29/22 09:07 PM
11/29/22 09:07 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
The parts list:
400 block, aluminum caps/studs
4.250x2.625x2.200 PEP crank
RPM rods, 6.535/2.200/.990 with ARP 2000s
4.375 bore w/ 12.5cc reverse dome pistons, 1.32CH 1/16×1/16×3/16 hellfire rings
440 source heads decked to get 80cc chambers
REV valves, new guides, two new seats amd a light bowl cleanup.
Comp 1.5 ratio steel rockers
Tensilemax retainers with CM locks
Isky 9915 springs at 1.930ish IH
3/8 push rods
Stock 68 383 valve covers
Bullet solid roller spec'd by Hardcore B
-.650 lift, 275/280 109 street roller
Holley SD intake with the floor dams removed
4150 1000cfm Thumper carb
1-7/8×3" headers
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098211
11/29/22 09:13 PM
11/29/22 09:13 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
That should be a very fun street car !!!!!
Re: street/strip 511" build with dyno results [Re: CSK] #3098257
11/30/22 01:02 AM
11/30/22 01:02 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Dyno sheet:
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098259
11/30/22 01:12 AM
11/30/22 01:12 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
An in progress shot
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098260
11/30/22 01:24 AM
11/30/22 01:24 AM
New York, USA
Chargerfan68 Offline
New York, USA
Very nice build and results! Similar build to the 505” in my ‘73 charger.
Any port work done to those stealths? Were they cnc stealths or standard? Those Comp Magnum rockers have been serving me very very well for 3 years now with track time and lots of street miles.
Good luck at the races…..should run real hard.
Re: street/strip 511" build with dyno results [Re: Chargerfan68] #3098261
11/30/22 01:35 AM
11/30/22 01:35 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
The heads were not ported. There has been speculation that a bigger intake and backing up the cam a few deg would net substantial gains.
Thank you for the feedback kn the rockers. I thought they were an exceptional value.
Still rocking the all aluminum crash box:
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098277
11/30/22 08:01 AM
11/30/22 08:01 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Nice, how much compression?
Re: street/strip 511" build with dyno results [Re: DusterKid] #3098284
11/30/22 08:29 AM
11/30/22 08:29 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
11:1 CR
I usually run a 50/50 mix of pump 91 and 110 on the street. 112 or 116 on the kit depending on the jets.
Ty!
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098286
11/30/22 08:56 AM
11/30/22 08:56 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice! I was surprised how low in RPM the power peaked but, it's a small head and intake ...AND header. Impressive to me for sure. I think this is an interesting comparison between the 512" AndyF posted with bigger heads and intake but smaller cam.
Re: street/strip 511" build with dyno results [Re: HardcoreB] #3098289
11/30/22 09:13 AM
11/30/22 09:13 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That's super inconspicuous, I dig it! Really impressive power from unported Stealths!
Re: street/strip 511" build with dyno results [Re: Blusmbl] #3098329
11/30/22 11:16 AM
11/30/22 11:16 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Looks fun!
Anyone else notice the "L2" AFR bank is consistently leaner than the "L1"?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: street/strip 511" build with dyno results [Re: Brad_Haak] #3098334
11/30/22 11:27 AM
11/30/22 11:27 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
275/280@.050?
Re: street/strip 511" build with dyno results [Re: fast68plymouth] #3098341
11/30/22 12:01 PM
11/30/22 12:01 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Originally Posted by fast68plymouth
Quote
275/280@.050?
274/283@.050 to be exact sir.
Re: street/strip 511" build with dyno results [Re: Brad_Haak] #3098343
11/30/22 12:02 PM
11/30/22 12:02 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Originally Posted by Brad_Haak
Looks fun!
There was an exhaust leak developing on the last two pulls.
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098345
11/30/22 12:03 PM
11/30/22 12:03 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
For the morning crew
Re: street/strip 511" build with dyno results [Re: Jeremiah] #3098346
11/30/22 12:04 PM
11/30/22 12:04 PM
NC
440Jim Offline
440Jim  Offline
NC
IMO, That is a lot of duration for only 11.0 CR
Re: street/strip 511" build with dyno results [Re: HardcoreB] #3098368
11/30/22 01:11 PM
11/30/22 01:11 PM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Impressive build for sure, especially when you factor in the unported stealths, which are the current cork in the system.
The Holley SD never disapoints, best low profile manifold for the BBM ever made.
I would think that cam has too much duration also, but it seems like a great match for the rest of the combo.
Re: street/strip 511" build with dyno results [Re: powertrip] #3098372
11/30/22 01:17 PM
11/30/22 01:17 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Iplease keep the following in mind - ts a small tire stick car that races om limited or no prep. Not a bracket car that hooks a 14x32 in the car wash lol. I'm more into all out racing cmpetition than the stop light to stop light fonzi car show thing too. 1/8th or 1/4 mile from a dig.
The plan is a bigger intake/glass hood and some CNC work on the heads. I don't want the engine making 500 ft lb of tq at 2500 because it makes the car undrivable on the street. Those of us that have big hp cars woth a limited tire and a stick know what I am getting at here.
As it sits we will make 800+ on nitrous.
To all of the " i would have done it different " cfolks...what would you do and why? Keep in mind that this is a small tire, limited prep street strip car with a stick.
Page 1 of 4 1 2 3 4
