Re: Where to find Grade 8 Sex Bolts, Mating Screws?
[Re: moparjim79]
#2922113
05/13/21 01:40 PM
05/13/21 01:40 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Tell us what you're using them for They are being used to attach a steel liftgate system to an aluminum trailer. I need the flush head sex bolts so they can mount the steel flange to the aluminum tube, and then install sheeting, or trim over to hide the fasteners from view. Its much more aesthetically pleasing than a bunch of bolts sticking through the side of a trailer. I want to use grade 8 because of their hardness, and shear strength properties. Stainless might work, but its not the same as grade 8.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#2922121
05/13/21 02:13 PM
05/13/21 02:13 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Tell us what you're using them for They are being used to attach a steel liftgate system to an aluminum trailer. Have you enough material thickness to prevent pull through after countersinking? What electrolysis prevention measures are you taking?
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2922127
05/13/21 02:29 PM
05/13/21 02:29 PM
hp383
State of Confusion
Tell us what you're using them for They are being used to attach a steel liftgate system to an aluminum trailer. Have you enough material thickness to prevent pull through after countersinking? What electrolysis prevention measures are you taking? Yes there is plenty of thickness, and the holes through the tube are slugged so it can't collapse. The aluminum is a custom double hollow with 0.3125" wall, the steel flange is 1/4" plate. We will use the same electrolysis prevention as is used to attach steel axle subframes to aluminum trailers, or steel tongue, gooseneck, kingpin, and A frame couplers. This isn't something being built in my backyard. I was hoping there was a diverse enough occupational background among the members to help source a piece of hardware that I had not ever tried to locate before.
[Re: hp383]
#2922199
05/13/21 06:47 PM
05/13/21 06:47 PM
Posts: 20,335 Park Forest, IL
slantzilla
Park Forest, IL
What you are actually looking for are countersink bolts with Allen heads? We get all out stainless from Applied. McMaster-Carr probably has what you need too.
[Re: slantzilla]
#2922244
05/13/21 09:25 PM
05/13/21 09:25 PM
Posts: 1,663 Cleveland, OH
TWS
Cleveland, OH
OK, I had to google "sex bolts" to see what they were, and holy cow! This is what I have been looking for high and low, calling up fastener vendors all over the place with no luck. I had never heard of the term before. The thing that is disappointing is that with all of the specialty fastener companies all over the country that were contacted, none had ever seen what I was showing them in the pics. So, thank you hp383 for posting this question...my fastener quest has likely been solved; quite a variety of potential sources out there. Parts Wanted - Challenger SE Trim Screws
[Re: TWS]
#2922257
05/13/21 09:46 PM
05/13/21 09:46 PM
3hundred
Colleyville
OK, I had to google "sex bolts" to see what they were, and holy cow! This is what I have been looking for high and low, calling up fastener vendors all over the place with no luck. I had never heard of the term before. OMG! 40+ years in the structural steel business, countless AISC, RCSC, TSSI meetings and I've NEVER heard the term before. I really thought it was a typo for hex bolts and was nonplussed when he mentioned countersunk. Never too late to learn something new.
[Re: hp383]
#2922288
05/13/21 11:47 PM
05/13/21 11:47 PM
Posts: 23,295 Here
jcc
Here
Tell us what you're using them for They are being used to attach a steel liftgate system to an aluminum trailer. Have you enough material thickness to prevent pull through after countersinking? What electrolysis prevention measures are you taking? Yes there is plenty of thickness, and the holes through the tube are slugged so it can't collapse. The aluminum is a custom double hollow with 0.3125" wall, the steel flange is 1/4" plate. We will use the same electrolysis prevention as is used to attach steel axle subframes to aluminum trailers, or steel tongue, gooseneck, kingpin, and A frame couplers. This isn't something being built in my backyard. I was hoping there was a diverse enough occupational background among the members to help source a piece of hardware that I had not ever tried to locate before. Note, electrolysis concerns are greater between SS & Alum than Alum and steel, contrary ro what most think. Seems to me the fastener design sought would have a difficult time achieving a typical marked grade 8 rating, or the needed clamping load.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: Sniper]
#2922290
05/13/21 11:49 PM
05/13/21 11:49 PM
Posts: 23,295 Here
jcc
Here
Nope - you can't. I don't think you can harden stainless, even though it's already hard. No way stainless is grade 8. When you need grade 8, you need grade 8! 17-4 Stainless is available and very comparable strength wise to typical grade 8, and far superior to typical grade 2 stainless fasteners. Physical Properties: Melting Point: 2560 - 2625°F (1404 – 1440°C) Density: 0.282 lbs/in3 / 7.8 g/cm3 Modulus of Elasticity in Tension: 28.5 X 106 psi / 197 GPa Mechanical Properties: Condition: Solution Treated (A) Tensile Strength Minimum (psi): 160,000 Yield Strength Minimum 0.2% offset (psi): 145,000 % Elongation in 2” Typical: 5% Hardness: Rockwell B85 Condition: Hardened + Aged (TH1050) Tensile Strength Typical (psi): 200,000 Yield Strength Typical 2% offset (psi): 185,000 % Elongation in 2": 8% Hardness: Rockwell C35 Condition: Aged (H1075) Tensile Strength Typical (psi): 175,000 Yield Strength Typical 2% offset (psi): 165,000 % Elongation in 2": 8% Hardness: Rockwell C37 Condition: Aged (H900) Tensile Strength Typical (psi): 210,000 Yield Strength Typical 2% offset (psi): 200,000 % Elongation in 2": 7% Hardness: Rockwell C45 For reference sake, its likely double the cost of typical SS. Irrelevant if no one makes sex bolts in 17-4 stainless. Ouch.
[Re: jcc]
#2922384
05/14/21 09:49 AM
05/14/21 09:49 AM
Posts: 6,511 nowhere
Sniper
nowhere
True, back in my sailor days I at one time used to refurbish satellite communications antenna. Aluminum castings held together with "CRES" bolts, which is what the Navy calls stainless steel, as in corrosion resistant. Every bolt hole in the aluminum was helicoiled and liberal amounts of antisieze was used to help prevent corrosion. It was very easy to tell when antisieze was not used, because you had to fix the resultant broken off bolt. Be sure to account for the antisieze's different lubricity and it's effect on the torque values.
[Re: Stanton]
#2923214
05/16/21 06:50 PM
05/16/21 06:50 PM
hp383
State of Confusion
These what you're after? When it comes to grading bolts not all types are graded in the conventional numeric way. Particularly when you're dealing with socket heads. https://spaenaur.com/catalog/B200/#zoom=zGuess these aren't what you're after, huh? Thank you but no, those are socket head cap screws. Sex bolts are a different product.
[Re: jcc]
#2923218
05/16/21 06:58 PM
05/16/21 06:58 PM
hp383
State of Confusion
I do not want a stainless steel fastener. I know that stainless steel and aluminum do not play well together. I don't know why many replies seem to assume that is what I am looking for. I am only able to find stainless steel. But want just a normal grade 8 fastener, possibly zinc coated, or black oxide, the finish isn't my main concern.
[Re: Stanton]
#2923220
05/16/21 07:02 PM
05/16/21 07:02 PM
hp383
State of Confusion
So all along I thought you meant "hex" bolt but your last reply got me curious so I GOOGLED "sex bolt" . Well Good luck finding those things in grade 8 !!! I doubt they even come in Grade 2 !!! The head would be the weak point. I have found them in grade 5 So I will keep hunting.
[Re: hp383]
#2923268
05/16/21 09:01 PM
05/16/21 09:01 PM
Posts: 23,295 Here
jcc
Here
I do not want a stainless steel fastener. I know that stainless steel and aluminum do not play well together. I don't know why many replies seem to assume that is what I am looking for.I am only able to find stainless steel. But want just a normal grade 8 fastener, possibly zinc coated, or black oxide, the finish isn't my main concern. "I can find them in 18-8 Stainless, but I would really like to have Grade 8." quoted from your opening post. This could be understood that you wanted grade 8 Stainless, and you have now cleared that up. I am surprised you found Grade 5, Good luck in your quest.
[Re: hp383]
#2923329
05/16/21 10:50 PM
05/16/21 10:50 PM
Posts: 10,308 A Red State
SNK-EYZ
A Red State
In your original post where you said Prefer to find a tapered seat style for a flush mount. is part of what confuses people to what you want since it looks like the sex bolt isn't designed to be flush where a flat socket head bolt IS designed to be flush. Yes, you could make the sex bolt flush, but it doesn't look like it has a tapered seat under the head.
[Re: SNK-EYZ]
#2923489
05/17/21 01:09 PM
05/17/21 01:09 PM
hp383
State of Confusion
In your original post where you said Prefer to find a tapered seat style for a flush mount. is part of what confuses people to what you want since it looks like the sex bolt isn't designed to be flush where a flat socket head bolt IS designed to be flush. Yes, you could make the sex bolt flush, but it doesn't look like it has a tapered seat under the head. They are available in button head and tapered seat from most sources. The problem is finding a larger diameter, in a grade 8 steel. It may not be available, and if that is the case I will look into other means of fastening the lift gate side posts to the trailers.
[Re: Sniper]
#3097579
11/27/22 04:02 PM
11/27/22 04:02 PM
Posts: 1 Seattle
LarryJoew
Seattle
I suppose that you should tell us where you want to order it. Update, I didn't say that they won't be able to make the shipping in some particular state or something; I just asked to know which websites to advise you. There are a huge number of variants for you; I just wanted to find something more affordable and near you. The best option at this point for you is https://www.scrooz.com.au/nuts-and-bolts/ website, selling many different bolts and stuff for construction and reparation. Be sure that you find the right one and pick all the options correctly to avoid mistakes and problems after shipping.
