Oil ring clearance?
#3097143
11/25/22 09:55 PM
11/25/22 09:55 PM
Posts: 2,051 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Filing the rings today for my fresh RB build and checked the oil scraper ring gap. Mfg says a minimum of .015". These have just over .060". I'm thinking that they are mis-boxed. I don't want anywhere near that much gap. The really annoying thing is I've had the rings for about 6 months while trying to procure the rest of the parts (rods, crank, bearings, ect), plus, can't call Total Seal until Monday. I just thought I was going to put this together this weekend. Last week we had a set of JE rings for a brand X engine that was mis-boxed, had about .250" gap. Crazy. (I build a street engine for a customer a few months ago (using a set of Hastings "drop in" rings) that had the scraper ring at approx .040" gap. Hastings said then anything less than .055" was good. Really?)
Brian
Re: Oil ring clearance?
[Re: Gabby63]
#3097359
11/26/22 08:10 PM
11/26/22 08:10 PM
'72CudaRacer
Mooresburg, Tn
I found this on my ring instruction sheet ,
The oil rings only needed to be checked to ensure they were greater than 0.015 inches. The oil scraper ring does not need to be gapped. Once you have all the rings gapped to the correct settings for their assigned cylinder bore, weigh the set and record the value .
Gary The scraper rings have over .060" gap, closer to .070". The rings look like they are for a 4.350 bore. When I put one in my calipers at 4.350", the gap is approx. .025" The package is marked 4.380" Brian
[Re: '72CudaRacer]
#3097416
11/26/22 11:38 PM
11/26/22 11:38 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
Do you have a manual fish scale? If so try installing the oil rings only on one piston and install it upside down and make something t=you can put around the wrist pin (Tye rap maybe) and see how much pressure in lbs it takes to pull them a ways I'm thinking that one of the major ring makers have three different design oil rings, standard tension, low tension and ultra low tension The last bracket motor I put together for my Cuda had the ultra low tension ring set along with .043 sealing ring widths, it rotated very easily, (less than 15 Ft Lbs.) and went faster than I expected. I built it with the plan on using a vacuum pump, friction takes power to overcome
[Re: Gabby63]
#3097875
11/28/22 06:41 PM
11/28/22 06:41 PM
'72CudaRacer
Mooresburg, Tn
It would be nice if you had a 4.350 taper ring to test your theory , place these rings in then measure . I bet you would not have the .015 required gap . The last set I used were large , not .060 large but no issues either . Gary As a matter of fact, I have a 440 in the shop that is 4.350 bore and you are correct, they don't fit. (ends butt tight when squared in the bore) Brian
[Re: '72CudaRacer]
#3097911
11/28/22 08:03 PM
11/28/22 08:03 PM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...late to the party, but the specs for my Mahle stroker pistons kit (part# 930271030, SB 408") supplier rings (par# 4035MS-112) are as follows:
- 4.030" + 0.005" file fit ring set, 1.0 mm top ring, 1.0 mm second ring (HV385 steel/steel), 2.0 mm oil ring (Napier w/ standard tension)
The oil ring gap specifically is called out as "min. 0.015", and my measurements were all 0.024/25.
