Re: COMPACT PRO STOCK
[Re: A/MP]
#3095816
11/20/22 03:45 PM
11/20/22 03:45 PM
Posts: 19,633 north of coder
moparx
well, a short wheel base car with a TON of hp can be a handful. add the wrong alignment specs to the front suspension, and "stuff" WILL happen. this car only had a 440+6/727/dana 60 combo, and the below was the results. in order to fit the engine, the struts were swapped side to side, which also dictated the rack to move to a front-steer position. this caused two major factors to happen. first, swapping the struts caused the caster to go WAY negative. think of an out of control shopping cart with wobbly front wheels. second, the ackerman went way wrong, allowing the outside front wheel in a turn [correction maneuver] to sharply turn in a very decreasing radius than the inside wheel, thus resulting in a ton of tire scrub, similar to locking a tire on ice. zero ackerman would have been better, but neither of the mentioned alignment items were tried to be corrected. only the toe-in was set, but i forget what it was set to. luckily, no one was hurt, but the car was a write off. the drivetrain was later installed in a duster, and i "think" it goes [or went] mid to low 10's. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
![Name: scan0005.jpg
ID: 471734 scan0005.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/471734/filename/scan0005.jpg) ![Name: scan0006.jpg
ID: 471735 scan0006.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/471735/filename/scan0006.jpg)
[Re: A/MP]
#3095850
11/20/22 06:34 PM
11/20/22 06:34 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Isn't the Colt the same as the Plymouth Arrow which Bob Glidden successfully campaigned in Pro Stock? Ran 8.50's, won several events and set speed record several times.
[Re: John_Kunkel]
#3095883
11/20/22 09:40 PM
11/20/22 09:40 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
Similar but not the same, the Colt had a 90" wheelbase and the Arrow was 92". I am not certain but IIRC NHRA allowed them to stretch the wheelbase to 99". I think all the pro stock cars are 105" now.
[Re: John_Kunkel]
#3095886
11/20/22 09:43 PM
11/20/22 09:43 PM
Posts: 20,213 Park Forest, IL
slantzilla
Park Forest, IL
I believe the Arrow had a slightly longer wheelbase, better aero, and a much lighter small block in the nose.
Colts with a Hemi were well known to be "twitchy".
[Re: RTSE4ME]
#3096314
11/22/22 01:44 PM
11/22/22 01:44 PM
Posts: 1,561 yarnell,az
mopacltd
yarnell,az
I stretched mine to 105 inch and still run with a arms. Been as quick as 8.30's with 542 cid BBM
[Re: mopacltd]
#3096471
11/23/22 08:47 AM
11/23/22 08:47 AM
Posts: 1,337 Oregon
earlymopar
Would sure like to see some pictures.
I stretched mine to 105 inch and still run with a arms. Been as quick as 8.30's with 5442 cid BBM
[Re: theraif]
#3096583
11/23/22 02:57 PM
11/23/22 02:57 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
FWIW the heads up car we run is 96" wheelbase C3 Vette. It has been 1.08 60' 4.97 to the 1/8 and 171MPH in the 7.90's in the 1/4 so far and other than it being a totally stupid choice for a racecar it has not been an issue.
[Re: RTSE4ME]
#3096631
11/23/22 07:30 PM
11/23/22 07:30 PM
Posts: 2,059 MD
RTSE4ME
MD
