Re: Trick flow intake mods
[Re: Streetwize]
#3096131
11/21/22 07:06 PM
11/21/22 07:06 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Was it #1 and #2 intake ports or #2 and #4 intake ports you're talking about? I had never thought about the potential cross flow interference between #2 and #1 being 90 degrees away from each other on the firing order on a single plane single carb intake ![work work](/ubbthreads/images/graemlins/custom/work.gif) Thanks for opening my mind, a tiny bit ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
[Re: Cab_Burge]
#3096135
11/21/22 07:12 PM
11/21/22 07:12 PM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
184365721843657218436572184365721843657218436572184365721843657218436572
The thing Vizard keeps stressing is the exhaust pressure wave of the subsequent cylinder (1 after 2, 7 after 5) starts pulling against the first cylinder before the fill cycle is over...
What's confusing to me is he says the adjacent cylinder robs from the first one as a result, but you need to make sure the second one still can pull adequate air-fuel mixture if you can reduce the cross-flow issue. Maybe I need to speak "British English" instead of "American English" to fully understand him. Or maybe it's all just me...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3096250
11/22/22 09:33 AM
11/22/22 09:33 AM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
Brad,
I actually have met David a couple times through a mutual friend.
He's much more lively in person,
Something to consider is at 90 degrees after TDC through maybe 115 ATDC (depending on the stroke and rod ratio) that first cylinder is at or very near peak piston velocity so I can fully visualize how the second cylinder is getting a bit "ripped off"....this is how I interpret what's going on anyway. I may be completely 180 off...or at least 90 off, lol. So if the second pulls on the first somewhere in the cycle....as the english would say...."Fair Play to #7" lol
Again when the engine is approaching peak torque there should be a slight "ram effect" in the plenum which should minimize...or "balance" the port flows to all cylinders, so the gains are probably slight and only over a relatively small part of the powerband.
come to think of it, Mark GY3 runs one of my old street Dominators on his Stroker big block, he picked up about what I quoted on his motor...as far as I know he still runs it and seems happy with it.
[Re: Streetwize]
#3096256
11/22/22 10:03 AM
11/22/22 10:03 AM
Posts: 4,715 Wichita
GY3
Wichita
Yep, picked up exactly what you said it would on back to back weekends. The cylinders seem to fill pretty equally with it, too, as I keep an eye on plugs since we run nitrous now. I love it because it's stealthy and fits under my stock hood.
