Overdrive trans for small block 340
#3094171
11/14/22 03:33 PM
11/14/22 03:33 PM
Posts: 1,505 TN
SCATPACK 1
TN
Does anyone offer or has anyone installed an overdrive automatic from a later model truck/Dakota 5 speed into a Duster or Demon Have a 340 Demon that really would benefit from an overdrive trans Any help appreciated Any pictures or details of what work and modifications are required would definitely be appreciated Thanks Jerry
Old Geezer Racing
Re: Overdrive trans for small block 340
[Re: A727Tflite]
#3094251
11/14/22 10:59 PM
11/14/22 10:59 PM
Posts: 1,505 TN
SCATPACK 1
TN
Isn't that trans computer controlled? how do you get around that?? thanks for the response.
Old Geezer Racing
[Re: SCATPACK 1]
#3094258
11/14/22 11:51 PM
11/14/22 11:51 PM
Posts: 2,255 IL
furious70
IL
I have an a500 behind my turbo 383. You don't need to worry about the power or the BB bell on it, it would work well. It's operated with 2 pressure switches and a hobbs switch to downshift on WOT.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: SCATPACK 1]
#3094261
11/15/22 12:08 AM
11/15/22 12:08 AM
Posts: 3,077 Michigan
A727Tflite
Isn't that trans computer controlled? how do you get around that?? thanks for the response. The RE series MUST have the PCM to function properly, the RH needs either the PCM or a series of switches and and sensors to achieve 4th gear. 1,2 and 3 are fully automatic like a 904/727. Of course manual shift valve bodies can eliminate the need for much of the electronics.
[Re: BDW]
#3094335
11/15/22 12:26 PM
11/15/22 12:26 PM
A727Tflite
If you want a low first gear you can only get it standard in a 42/44. The 518/618 has 2.45 low like the 727. Plus the lighter internals are worth some e.t. especially behind a small block.
[Re: theraif]
#3094367
11/15/22 01:33 PM
11/15/22 01:33 PM
Posts: 4,206 New York
polyspheric
New York
W/r/t GV Yes, but: $$$$ OD is only 77.8% Has less effect on engine speed than any of the factory transmissions but can be used in any gear. This has the effect of “splitting the gears”, viz. creating an intermediate ratio between each pair of the original gear ratios. It allows double overdrive with an OD box.
I wrote an .xls that shows various ratio combination, RPM loss, MPH in gear, etc., PM for a free copy
Boffin Emeritus
[Re: polyspheric]
#3094422
11/15/22 04:39 PM
11/15/22 04:39 PM
Guitar Jones
I ran across a face book group for swapping the 8HP transmissions to LA and Magnum small blocks. I can't find it now, but there are stand alone controllers now with the popularity of gen 3 hemi swaps.
[Re: Guitar Jones]
#3095452
11/19/22 10:58 AM
11/19/22 10:58 AM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
I ran across a face book group for swapping the 8HP transmissions to LA and Magnum small blocks. I can't find it now, but there are stand alone controllers now with the popularity of gen 3 hemi swaps. Here you go! https://www.soundgermanautomotive.com/I'll be using them for my 8hp70 swap in the wife's durango. I'm also using 47RE in my challenger. Going to have a manual VB and a switch for OD. Pretty basic stuff.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
