Re: How high do you rev your 440s? [Re: mopar873] #3093221
11/10/22 07:15 PM
11/10/22 07:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Well I am working on one that should turn 10000 and live.
I think the key here is an aftermarket "4-bolt main" block as well as some other good bottom end parts. But by the time you're done with that its almost pointless to put wedge heads on it - you may as well just step up a tad more and go with a full hemi.
Re: How high do you rev your 440s? [Re: Brad_Haak] #3093229
11/10/22 07:49 PM
11/10/22 07:49 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Originally Posted by Brad_Haak
As in 3.75" stroke combos, not 4.15" +
My 400/455 with the 3.75 crank spins to 8k. That gets my junk into the 8's on pumpgas. Thats Molnar crank n rods & Ross pistons.
Re: How high do you rev your 440s? [Re: rebel] #3093256
11/10/22 09:08 PM
11/10/22 09:08 PM
PA
moparacer Online content
moparacer  Online Content
PA
Originally Posted by tjmarcus1
I must hear more about this 10grand motor!
If you are at the pull the day they try it, you will definitely hear something.....
Once.... tonguue
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: How high do you rev your 440s? [Re: moparacer] #3093259
11/10/22 09:28 PM
11/10/22 09:28 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I saw a guy take one to 7500 with stock rods once.....It was pretty epic...I could see thru the block after that run...
Re: How high do you rev your 440s? [Re: AndyF] #3093338
11/11/22 09:08 AM
11/11/22 09:08 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Originally Posted by AndyF
You have good heads and a big cam for a stock stroke engine so I wouldn't be surprised that it is still pulling at 7000 rpm. Most strokers lay over well before then, even with MW heads.
Yeah, it's got no problem carrying the HP beyond the 6800 peak point. Old and new comparison chart below.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: How high do you rev your 440s? [Re: Brad_Haak] #3093356
11/11/22 09:55 AM
11/11/22 09:55 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Light weight crank-rods-pistons I can see some rpm and live. My 499 (400 block) was dynoed to shift at 7500-8000 l, live at 7500 but the most hp at 8000. Torque was 650? @ 5700. Kenny L built it.
Re: How high do you rev your 440s? [Re: cudaman1969] #3093460
11/11/22 01:48 PM
11/11/22 01:48 PM
NY
challenger451ci Offline
NY
I used to shift my 451 stock 440 crank at 7200 and it would go through the traps at around 7600 on the sauce. Over 100 passes like that.
Re: How high do you rev your 440s? [Re: Dragula] #3093465
11/11/22 01:54 PM
11/11/22 01:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I dont know on a 440 anymore but we shift our 5" stroke BBM at 7500 smile
Re: How high do you rev your 440s? [Re: moparacer] #3093596
11/12/22 12:15 AM
11/12/22 12:15 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Oh yea of little faith....I should not have said anything. We routinely spin the pulling truck stuff almost 9 grand for about 15 years now. I am not saying or suggesting that the OP here should be doing anything like this and a lot of the advise here is spot on. Back to my cave.... Todd
Re: How high do you rev your 440s? [Re: sasquatch] #3093649
11/12/22 08:50 AM
11/12/22 08:50 AM
Loudoun County, VA
Loudoun County, VA
Originally Posted by sasquatch
... I am not saying or suggesting that the OP here should be doing anything like this and a lot of the advice here is spot on. Back to my cave.... Todd
NP, Todd. Wasn't thinking you were telling me anything crazy. And don't hide in the cave on my account! up
Re: How high do you rev your 440s? [Re: sasquatch] #3093655
11/12/22 09:43 AM
11/12/22 09:43 AM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
Believe me Todd I wasn't bashing you either! Your reputation SPEAKS LOUDLY! I was wanting to learn more about it to see what you were planning.
Re: How high do you rev your 440s? [Re: Brad_Haak] #3093712
11/12/22 01:59 PM
11/12/22 01:59 PM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
Brad,
Mine is a 3.75 stroke .055 over 440. I have an eagle crank, Manley H-Beam rods and Ross pistons. Two weeks ago, I went through the traps @ 7300 rpm.
Re: How high do you rev your 440s? [Re: aarlucas] #3093891
11/13/22 10:25 AM
11/13/22 10:25 AM
Loudoun County, VA
Loudoun County, VA
Originally Posted by aarlucas
Brad,
I'll be interested in what RPM mine will spin thru the traps on a burner pass... 7100-7200... ?
Re: How high do you rev your 440s? [Re: J_BODY] #3094074
11/14/22 08:56 AM
11/14/22 08:56 AM
gregsdart Offline
gregsdart  Offline
Originally Posted by J_BODY
Like Greg mentioned….. data recording can definitely make you adjust your shift light. It’s pretty interesting how much “time” can go by from: see shift light, arm moves shifter, trans makes mechanical shift
J, i was surprised to see a 250 rpm above shift point on my logger. I use an rpm switch and airshifter, so component delay is also present in the trans. The 1/2 shift shoulded 250 rpm above settings, 2/3 shift 150 above. Of course it is all relative to ET and trans setup. A 14 second stocker obviously will have less rpm gain than an 8 second car.
Re: How high do you rev your 440s? [Re: gregsdart] #3094110
11/14/22 11:56 AM
11/14/22 11:56 AM
Loudoun County, VA
Loudoun County, VA
I tried using a shift light and decided it wasn't any better for me. Last time I had two different "redline" marks on my tach, one for 1-2 (pointing straight up) and one for 2-3 (about 300 RPM higher). It'll be interesting on the new playback tach to see where I *think* I'm shifting vs where it actually shifts.
Re: How high do you rev your 440s? [Re: sasquatch] #3095449
11/19/22 10:50 AM
11/19/22 10:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I just built a 1600+ cfm for a 10,000 rpm puller truck with an old Pro Stock Hemi and it made 1340+ hp and just went 67 feet past the 300 mark on the first pull. Some love rpm's and some don't...My little 470 junk box loves 7000+ even with the 1/2 pick up mod and has for many years.....
