Solid lifter question #3092525
11/08/22 11:00 AM
11/08/22 11:00 AM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
Can any brand of solid flat tappet lifter be used with any brand of solid flat tappet lifter cam?
Re: Solid lifter question [Re: 6PAX] #3092548
11/08/22 12:44 PM
11/08/22 12:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Intended for use in the same engine?
Probably.
Between engines?
Less likely.
Boffin Emeritus
Re: Solid lifter question [Re: polyspheric] #3092820
11/09/22 12:05 PM
11/09/22 12:05 PM
Detroit area
Detroit area
Yes, same engine and the engine hasn't been run yet so the lifters I have are unused. Just wondering if I can use a different brand of cam than what the lifters are.
Re: Solid lifter question [Re: 6PAX] #3092821
11/09/22 12:06 PM
11/09/22 12:06 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Only a few companies made / make lifters, regardless of which cam company's name's on the box.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Solid lifter question [Re: Brad_Haak] #3092840
11/09/22 01:22 PM
11/09/22 01:22 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the cam grinders don't make lifters of any type. they just package with their name on the box. most flat tappet performance stuff is johnson. talk to howards and pretty sure they'll tell you yours are johnson lifters. pretty sure comp cams use johnson. second tier cam grinders may or may not use offshore or mexican lifters.
